Results 1 to 10 of 11
Thread: Cam belt change, do I get it done?
    Regular Member purple170503's Avatar
    kent
    Default Cam belt change, do I get it done?
    I am just about to get car serviced for it's 4th year so would be interested to hear what sort of prices people have paid but I have also been told that I need the Cam belt changed. It's only done 30k so not sure what to do.
    It's a vectra 1.8vvti, thanks for the advice
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    how old is the car fella
    11 Post(s)
    Official recommendation change is:-
    Z18XE 6 yrs or 60,000 miles
    Z18XER 10 yrs or 100,000 miles
    Remember to also change the water pump.
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    After only 4 years and 30k, I wouldn't, unless you really want to. I certainly wouldn't wait until anywhere near VX recommendations though.
    Regular Member shadyone's Avatar
    Nov 2007
    Northants
    Waterpump not driven off the timing belt on a vvt so no need to get it changed and to be honest i'd be leaving the belt for the time being.
    Didnt change mine till 107k so i'd confident you could run it to at least 50k.
    kent
    It's an 06 plate...should I get the brake fluid and coolant done as well? not sure if they fo that in the service
    Nov 2007
    Northants
    Brake fluid maybe not a bad idea but i'd leave the coolant if it has the proper longlife red stuff, should be plenty of life in it yet.
    kent
    Quote Originally Posted by shadyone View Post
    Thanks very much for the advice, I will do that then, hopefully won't be as expensive as a I first thought then. Been quoted about £240 from Vx and a another local garage about £175 for a full service following the Vx chart but would have to pay on top for the brakes
    11 Post(s)
    Quote Originally Posted by purple170503 View Post
    To change the fluid?
    Yes, separate charge as not part of the fixed service price. Only cost me something like £25 or £30 for my local Vauxhall garage to do it though. Approx ¼ hrs labour and a couple of quid for the fluid.
    kent
    Just picking myself up..just been told by Vx that the service will cost me £290 including the brake/clutch fluid change!! The other garage that told me £175 have now said £250 following the Vauxhall service plan.
    I so wish I was a mechanic! Or is that a fair price? Perhaps I'm just tight!!
  1. Cam belt change
    By jacko52 in forum Diesel Engine related
    Last Post: 10th January 2011, 22:01
  2. when to change Cam belt
    By rollercoaster63 in forum Vectra C / Signum Car Chat
    Last Post: 25th August 2009, 19:50
  3. Cam Belt Change
    By darrenmac in forum Engine & Drivetrain
    Last Post: 17th June 2008, 20:59
  4. Cam belt change now or later
    By mr.4dil in forum Engine & Drivetrain
    Last Post: 20th February 2008, 22:57
  5. 03 1.8 sxi cam belt change
    By mickeyc in forum Engine & Drivetrain
    Last Post: 10th October 2007, 08:18
how often do you change cambelt on vectra 2.8 turbo
