Thread: Boost sensor
    Sep 2009
    Glasgow
    Default Boost sensor
    Hi all have cleaned again last time i done it, didn't notice much difference but this time i cleaned it properly and now have like a little yellow bit in the middle, but the top half of the yellow nit is still black, is this right, does anyone have any pics of a new boost sensor, it probably is just muck but i didn't want to scrape at it and brake sensor.
    Regular Member Daywalker's Avatar
    Aug 2007
    Kaunas raj
    Vehicle : Qashqai
    Trim : Visia
    Engine : 1.5dci
    Year : 2010
    I think so mine is the same can clean most of it but still a small bit of black at the end, perhaps if you soak in some WD40 next time it may shift it. HTH
    Sep 2010
    Hartlepool
    I have read a thread on this and had a couple of comments on threads of my own about cleaning the boost sensor which I hope to do very shortly.
    The comments, along with the How2, all say to use the carb cleaner and also to use a small soft brush. This may get the muck out from the tip of the sensor that you say is still black.
    Hope this helps.
    Sep 2009
    Glasgow
    Hi all spent a good half hour cleaning sensor all black stuff gone now, the little yellow bit should be all yellow and starts thin and thickens at end.
    Sep 2010
    Hartlepool
    The question is, is your car running any better for cleaning the Boost Sensor?
    Sep 2009
    Glasgow
    yep, smoother and more pull, was lagging a bit before hand.
    Regular Member robk6112's Avatar
    Halifax
    how do you clean it please?
    Halifax
    anyone?
    Sep 2010
    Hartlepool
    There's a How2 on this site for cleaning boost sensor.
    I'll try and find it and post a link here for you.
    Sep 2010
    Hartlepool
  1. boost sensor on the 120
    By SarahP in forum Engine & Drivetrain
    Last Post: 2nd April 2012, 22:25
  2. Boost Sensor & 10K Boost
    By hebdendave in forum Diesel Engine related
    Last Post: 13th February 2011, 17:43
  3. CDTI 150, 10k Boost De-Coked & New Boost Sensor
    By Vaux-Man-G in forum Vectra C / Signum Car Chat
    Last Post: 4th January 2010, 12:02
  4. cleaned boost sensor and still shows over boost
    By chowwie in forum Engine & Drivetrain
    Last Post: 14th November 2008, 09:23
