Results 1 to 10 of 16
Thread: Emissions Warning Light
    Regular Member fifesri's Avatar
    Sep 2009
    Fife
    Default Emissions Warning Light
    My wife has come back from work - 12 mile drive- the emissions light was on all the way home.
    No reduction in performance but i would like to know what has caused this and what needs done to resolve it,
    Any ideas lads?
    Thanks in advance
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 85000
    At a shout one of the 2 lambda sensors.
    Pinched from another thread
    Have you tried the 'pedal test' on the car to see if that brings up any fault codes?
    With the ignition off, press and hold down the accelerator and brake pedals as far as they go. Now turn the ignition to position 2 so the dash lights come on, but DO NOT START THE ENGINE!
    Any fault codes will either appear in the odometer display as ECNxxxxyy, or the engine management light will flash out the code. If you see it flash 10 - pause - 3 - pause - 10 - 1, then the stored code is P0301.
    For the codes in the odometer display, remove the last two digits (yy), then search for the 4digit xxxx code.
    Sep 2009
    Fife
    Thanks mate , believe it or not I have just printed off the test method to try it tomorrow !!
    Going by other threads , it's ok to drive provided it's not flashing ??
    Sep 2009
    Fife
    Is it a coincidence that I put £25 worth of ASDA unleaded in it today ??
    BTW its a 2003 1.8sri
    Yer Maws Bedroom
    40 Post(s)
    Engine : 1.8 iVtec
    Mileage : 85000
    Seems to be about the only issue on the 1.8, mine is the same but still drives normally.Code 0036, second Lambda. Theres a list of fault codes somewhere on the site.
    Sep 2009
    Fife
    Thanks mate appreciate the replies , maybe a good blast'll clear it ????
    Yer Maws Bedroom
    40 Post(s)
    Engine : 1.8 iVtec
    Mileage : 85000
    Sep 2009
    Fife
    Top bloke , cheers again
    Yer Maws Bedroom
    40 Post(s)
    Engine : 1.8 iVtec
    Mileage : 85000
    Quote Originally Posted by fifesri View Post
    Naw, tbh if its faulty its gonna need replacing. Ive not done mine yet as the front pipe doesnt look too healthy, doubt it will survive someone trying to remove it, i'll just get a new one when the front pipe needs replacing
    Sep 2009
    Fife
    Anyone else haad rhis problem and thought their Vec felt better/faster and smoother ? The light is still on btw.
  1. emissions warning light on constantly.
    By Casper85 in forum Engine & Drivetrain
    Last Post: 2nd August 2012, 16:22
  2. Emissions warning light on
    By peterb11 in forum Engine & Drivetrain
    Last Post: 18th March 2011, 17:03
  3. Emissions Warning Light
    By Electricdave in forum Electrical & ICE (including SatNav)
    Last Post: 2nd September 2010, 21:12
  4. Emissions Warning Light
    Last Post: 28th August 2010, 19:23
  5. Emissions warning light
    By MultiDropper in forum Vectra C / Signum Car Chat
    Last Post: 29th April 2010, 21:19
