Results 1 to 10 of 21
Thread: Is this really the issue? Will a new EGR fix it?
    Oct 2009
    North Lincolnshire
    Default Is this really the issue? Will a new EGR fix it?
    EGR Fault Code - is this the problem?
    Hi guys,
    Looking to pick someones brain with a little more knowledge than my own. My car (Z19DTH Vectra) has been suffering from the dreaded "no power until 2500rpm then boost" and "Limp mode" problems for a little while now. Reading all the threads i thought my swirl valves had gone and would need a new inlet manifold etc.
    However, i had someone run Tech2 on it and the only faults it came up with were:
    P0400 Exhaust Gas Recirculation Flow Insufficient Detected B-036
    P2279 Intake Air System Leak Detected B-035
    The guy who scanned it for me said it was likely my EGR is knackered and that this would be what was causing the problems
    Does this sound right to you? Would a knackered EGR really cause my car to run so poorly? I have tried to clean it as it was really clogged up but if anything it has made it worse so I will look to get a new one if this is the problem.
    Hope you can help with advise,
    Thanks,
    Dave
    Regular Member DeanF's Avatar
    Nov 2007
    Staffordshire
    Quote Originally Posted by DAS2 View Post
    Hi guys,
    Thanks,
    Dave
    Swirl valves won't always show up as a fault code or the code's can be misinterpreted, best way to check them is visually, Remove the Egr & clean it thoroughly , If this helps / cures, your on the right track. It takes a few mins to check the swirl valves, just pop the engine cover off & take a peek..
    Dean
    Oct 2009
    North Lincolnshire
    I have tried cleaning the EGR and it has made no differenve if not making it worse and the Exhaust emissions light is on all the time.
    I have visually checked the swirl valves and the connector seems to be ok - doesnt seem loose or anything.
    Dave
    Feb 2007
    North west
    after cleaning egr valve clean the boost sensor too. Also dose of redex in the fuel helps before and after a clean. Light goes out after a few days if you have cleaned it well. I have heard its after x number of restarts but i cant remember how many.
    Nov 2007
    Staffordshire
    Dave
    It's not just the connector though, Get somebody to rev it up high whilst you watch the swirl Valves, There should be no gunky/oily mess around the valves. When they are under load/boost conditions, They are forced out of the inlet manifold & upwards, Loosing boost & catching the underside of the manifold restricting movement, If you see them move up/rattle whilst somebody reving it, then they are Bu66ered, as stated , under load this will be much worse ..
    Dean
    Oct 2009
    North Lincolnshire
    Did that - it just seemed to move backwards and forwards. I didnt notice anything that looked out of place.
    stockport
    Sounds like your EGR valve is jammed open.When this happens,the air being sucked in by your turbo is going back down the exhaust pipe through the open valve,hence no power until higher revs.It looks like the solenoid that moves the rod that controls the flap has burned out leaving the valve in the open position.
    As a quick fix,try blanking the valve at the exhaust inlet point with a 1mm stainless steel oval plate.This should stop the cycle and give you your performance back.(There's a "HOW 2" on EGR blanking).FELIXX.
    Regular Member mozzer99's Avatar
    bristol
    If your car has a DPF then consider having it manually regenerated or clean it out.
    I know it doesn't sound right but my limp mode and code 2279 was a blocked DPF.
    i was advised by member Benny (a Vaux technician) it was the DPF and he was right....
    http://www.vectra-c.com/forum/showth...82#post1283982
    Oct 2009
    North Lincolnshire
    Hmmm.... this is all a bit confusing.
    The swirl valves do not look oily or gunky - it is quite clean around them.
    I do not think the solenoid is stuck open as when i cleaned it the valve was moving freely and the solenoid was closed. However, when im driving if its in a LIMP type mode if I switch the engine off and straight back on I get boost again.
    Im just trying to figure out if i should spend £100 on a new EGR. If it fixes the problem then i dont mind but dont want to waste money.
    Dave
    Sodding Typical on Sea
    There is a school of thought that has tried fully blanking the egr, and yes though you do get the check engine light, you should restore full boost avoid limp mode and identify the EGR as the culprit.
  1. Air con issue
    By harts1.9design in forum Electrical & ICE (including SatNav)
    Last Post: 12th June 2012, 11:26
  2. hid issue
    By Morephun in forum Electrical & ICE (including SatNav)
    Last Post: 30th June 2011, 10:30
  3. Hid a serious issue ?
    By Elahi_786 in forum Electrical & ICE (including SatNav)
    Last Post: 29th November 2010, 02:28
  4. DAB issue
    By qsdjdan in forum Electrical & ICE (including SatNav)
    Last Post: 20th January 2010, 01:12
  5. key fob issue
    By doghead632 in forum Bodywork & Interior
    Last Post: 25th August 2009, 10:22
