Results 1 to 10 of 17
Thread: Pre Cat?
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Default Pre Cat?
    Seen alot of talk about a "pre cat" and its removal. What is it, What does it do and is it worth removing it on a 2.2 petrol for more horses?
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    newcastle
    hi mate a pre cat is just a cat befor the main cat. removing should free a couple of bhp if you have a perfomance exhaust.
    IIRC, it's all in the same housing, just after the 4 into 1 exhaust junction, beside the bulkhead.. there is no cat under the car on the 2.2's... to remove the pre-cat will require you to cut open the can and re-weld it ..
    i'd give it a miss personally..
    Regular Member Ride-On!'s Avatar
    Jul 2006
    Theres a village some where deprived of its idiot.
    Will only give you a few extra horses.
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    Welding mmm, think ill give that a miss. Thought it was just unbolting the pre cat pipe drilling holes around edge of the honeycomb then chissle it out, then replace pre cat and away toy go?
    as i said, IIRC it's a one -piece sealed unit with the main cat.. you could knock it out but you'll have to give up getting it mot'd..
    you could try a sports cat if you wanted, but the gains per pound are minimal..just get it mapped
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    Penny dropped, got you. O well thought id stumbled across a free mod.
    Regular Member dinac_cro's Avatar
    Nov 2007
    Zagreb/Croatia
    it is a bit old topic , but maybe some1 need this again
    http://www.astraownersclub.com/docum...precat-z22.pdf
    Regular Member beefycol's Avatar
    Nov 2007
    telford
    rushy you been looking on the z22se web site? its only on the vectra bs has a pre cat off the manifold, then the cat under the car. our cat is off the manifold, so dont we dont have a pre cat
https:www.vectra-c.comforumshowthread.php11809-Pre-Catpage2
vauxhall vectra c 2.2 pre cat removal
opel vectra c 2.2 16v pre-cat
