Results 1 to 3 of 3
Thread: cam sensor
    Sep 2010
    DURHAM
    Default cam sensor
    high guys a friend of mine is having probs will his vectra ..namely the cam sensor ive traced the problem to the wiring ....well the connector to be exact ..plus a burnt wire ....do vauxhall sell the connector so i can solder a new one on by any chance or is there any other way round it ..many thanks peter
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    See which wires go where, cut both connectors off and join together the individual wires. I would doubt VX sell the connector on its own, and they would need a special crimping tool to do the job properly. You can get squash connectors that have a sealing gel inside to water proof the joint. Or maybe even solder then together and put shrink wrap on?
    Depends how much effort you want to do.
    Sep 2010
    DURHAM
    thanx ste will pass your advice along !
  1. Replies: 3
    Last Post: 13th August 2012, 22:25
  2. P0141-04 o2 sensor heater circuit open (bank 1 sensor 2)
    By Mark1892 in forum Engine & Drivetrain
    Last Post: 3rd August 2012, 09:19
  3. Fitting & Installation of ABS Harness & brake Help sensor sensor
    By Elahi_786 in forum Suspension, Wheels & Brakes
    Last Post: 17th April 2012, 20:46
