Thread: P1125 - Throttle Actuator Malfunction
    Regular Member neill's Avatar
    Nov 2009
    Warrington
    Trim : SRI
    Mileage : 172000
    Default P1125 - Throttle Actuator Malfunction
    Hi, driving home from work today and the car slowed down and a spanner with car symbol came on the dash, its a vec c 1.9cdti 150.
    managed to get back home, and put opcom on, came back with
    (61) - Present
    tried cleari ng the fault and it wont clear
    so looked up on here but the code on here replates to throttle position sensor fault.
    Is the above code description the same?
    If it is the tps, does anybody know the cost of replacement one?
    cheers for any help
    Regular Member paul wingnut's Avatar
    durham
    Vehicle : vectra sri 150
    Engine : 1900 cdti 150
    throttle body will be faulty think they are about £140
    Nov 2009
    Warrington
    Trim : SRI
    Mileage : 172000
    could cleaning the throttle body sort it?
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Could be anything from the mechanicsim in the throttle housing, choked up throttle body, poor connections/wiring, throttle position sensor.
    Mines has a dodgy sensor but is going to the dealer tomorrow for confirmation.
    Gazza4
    preston
    for the sake of a throttle body gasket, i'd remove it and clean.
    and whilst you're there if its gunked up then do the same for the egr valve and the boost sensor
    check wiring for obvious damage then replace parts. check fuses to ensure one hasn't blown
    If you leave the battery off for a while this might clear the stored faults from the ecu
    if this fixes it then have a go at taking the butterfly valves off too. see the current thread about it..
    good luck
    Nov 2009
    Warrington
    Trim : SRI
    Mileage : 172000
    I decided to have a look at the tb, so removed it and it was thick with sut, after stripping and cleaning, it looked almost new. I then had a look at the entrance to the inlet, and that was the same. after cleaning that as best as i could i must have removed just over half a cup of sut. also removed the egr and strangly the egr looked new, the only thing that was dirty was the body that the egr bolts too. I also removed the boost sensor and that too was gunked up.
    Replaced everything with new gaskets, and used the fiat gasket for the egr body.
    Also did the fuel filter as that was black. Seems a lot more responsive now, still a bit weak upto 2k but pins me back better than it did before.
    No faults come up at the moment but i will wait and see, fingers crossed!!
    cheers guys
    Nov 2009
    Warrington
    Trim : SRI
    Mileage : 172000
    spoke to ****** soon, misses coming home, and did it again, grrrr
    Dont suppose anybody has a tb they want to sell me please
    Nov 2009
    Warrington
    Trim : SRI
    Mileage : 172000
    forgot to add that i did eventually fix the fault and alls i did was resolder the joints on the board inside the tb, fixed it not long after this post was created and thankfully to this day its still problem free. Hopefully this will help others.
    One thing to mention was the joints looked perfectly fine, but must have been dry as after i soldered them its been fine
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Quote Originally Posted by neill View Post
    I just took the plate off in October and finally got round to resoldering the joints - again like yours they looked ok, but dry. Resoldered them but haven't replaced the plate yet and I probably won't. No trouble from it.
  1. Fault Code P1125 for both 1.9 CDTI's - Throttle Position Sensor
    By GazVXLINE170 in forum Engine & Drivetrain
    Last Post: 25th August 2013, 17:54
  2. Code p1125
    By collyb in forum Engine & Drivetrain
    Last Post: 23rd April 2011, 23:46
  3. Error code p1125 throttle actuator...
    By CADT674250 in forum Engine & Drivetrain
    Last Post: 18th January 2011, 19:48
  4. P1125-0f
    By slipperysam1984 in forum Engine & Drivetrain
    Last Post: 13th December 2009, 20:29
  5. WTF is a THROTTLE ACTUATOR SENSOR/MODULE?
    By Vaux-Man-G in forum Vectra C / Signum Car Chat
    Last Post: 3rd November 2008, 15:55
p1125 throttle actuator malfunction
https:www.vectra-c.comforumshowthread.php118071-P1125-Throttle-Actuator-Malfunction
z19dt p1125
p1125-0f
zafira b throttle actuator
p1125 vauxhall 1.9 cdti
z19dth throttle body
z19dth p1125
p1125 z19dth
p1125 vauxhall astra throttle actuator control malfunction
Vauxhall P1125
Opel DTC P1125-80
throttle actuator vectra cdti
vectra c throttle actuator
throttle actuator malfunction zafiraastra cdti 1.9throttle actuatorthrottle control malfunction zafira 2007p1125 zafira bthrottle actuator feedback circuit malfunctionastra h throttle actuatorzafira b p1125astra h throttle actuator 1.9 issuesp1125 vauxhall
