Thread: TV Ariel
    Redditch
    Default TV Ariel
    After a bit of advise. I need to split a TV arial on the outside of a house and put the lead to 2 different rooms. There is no power externally so a powered splitter isn't ideal so does anyone have any ideas of the best way to do this other than running 2 leads from the arial itself.
    stockport
    Quote Originally Posted by Godzilla View Post
    Go to Maplins,(or similar electronics/electrical store)and ask them for an external coax aerial splitter box.Shouldn't be more than a few quid and will take a very short time to fit it.Cut your existing cable and run the extra cable plus the existing cable from it.If you need extra coax cable they will be able to sort that out for you as well.FELIXX.
    Regular Member BigWilko's Avatar
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    Yeah man, If you're in a streong signal area you might just get away with a passive splitter. It's worth a try. If it doesn't work try using 2 seperate single signal boosters in each room where there is power
    Mar 2007
    North East
    Or a mast head amp, basically a weather proof amp, power is fed up one of the coax feeds.
    Redditch
    Cheers for that was looking at the mast head amps, think I will go down that route. Thanks for the help
  1. Ariel
    By Carl83 in forum Styling
    Last Post: 31st July 2011, 11:18
  2. cdc 40 dab ariel
    By slugo in forum Electrical & ICE (including SatNav)
    Last Post: 21st June 2011, 18:14
  3. Help with ariel
    By ncfcsignum in forum Vectra C / Signum Car Chat
    Last Post: 14th September 2010, 23:24
  4. VX 220 Ariel Mod
    By ANDY H137 in forum Styling
    Last Post: 8th January 2008, 21:45
