Thread: Vectra V6cdti Cam Belt 04
    Bristol
    Default Vectra V6cdti Cam Belt 04
    Has anyone had this problem. On replacing the cam belt with all new rollers and adjuster. All the timming is correct but the belt is a little slack across the top between the cams. If you stat the car the car runs fine. Turn off engine and the belt is tight all round .Let sit for an hour and it goes loose again between the cams.
    Bristol
    Sorted
    what was the problem with , gonna do mine soon
    Quote Originally Posted by sb1uk View Post
    Sorted
    Thats gonna help others
    EVERYWHERE
    The 'tension' is killing me!
    Quote Originally Posted by diesel dog View Post
    Not the tension in between the sprockets though eh
  1. Vectra V6CDTI Fuel pump
    By sb1uk in forum Y & Z30DT Specific
    Last Post: 19th August 2012, 00:02
  2. Vectra V6CDTi
    By sb1uk in forum Engine & Drivetrain
    Last Post: 11th March 2010, 20:21
  3. Blue Vectra V6CDTi SRI Reg: DU54 V**
    By ukanalyst in forum Spotted or put a flyer on a Vectra C/Signum or Insignia?
    Last Post: 4th April 2007, 18:31
