Results 1 to 3 of 3
Thread: DTi Fuel Line Change
    Regular Member si_hoss's Avatar
    Apr 2009
    Stevenage, Herts
    Default DTi Fuel Line Change
    Hey all,
    Having the up-hill starting issue with my 2.2DTi, a guy at the dealer reckons it's most likely a pin hole somewhere along the fuel line. I've changed the leak off pipes and that cured nothing. So I'm wondering if anyone's attempted to change the entire line from the tank forward in an attempt to cure this?
    I've not looked at it at all, but anyone know if this is major surgery or an easy job? Obviously I'd buy original kit from Vauxhall, although not even priced it up.
    I'd appreciate any advice on this one!
    Si
    Administrator plasma's Avatar
    On the Forum
    357 Post(s)
    Engine : 150
    Mileage : 74000
    from what i.ve seen under the car there are 2 lines a fat one which supplies the diesel and a thinner one which is for the return. They are just clipped underneath. There is a quick release fitting on both just underneath the passenger footwell and think it is one piece from there to the filter housing
    Apr 2009
    Stevenage, Herts
    Quote Originally Posted by plasma View Post
    Thanks Plasma - I may look into it as a to do job as I do have a feeling this will cure my starting issues. The injector seals were changed 23k ago so surely not those, but saying that last time they were changed it made no difference.
  1. z22se fuel line
    By interespray in forum Engine & Drivetrain
    Last Post: 11th April 2012, 06:05
  2. fuel line
    By baz2003uk in forum Vectra C / Signum Car Chat
    Last Post: 2nd June 2007, 10:41
  3. Replacing fuel line 'HELP'
    By Matt21385 in forum Engine & Drivetrain
    Last Post: 21st November 2006, 17:31
vectra c dti quick release fuel line
vectra c dti fuel line
