Results 1 to 2 of 2
Thread: Radio problems on the AM band.
    Sep 2010
    Bristol
    Default Radio problems on the AM band.
    Radio AM band problems
    My 2006 Vectra radio has a problem on am band only.
    I live in Bristol and in certain area's it will play our local Radio Bristol, but no Talk Sport or 5 live.
    In other parts of the country, 5 live can come on with a weaker than normal signal.
    I have checked the aerial connection on the back of the radio and all seems fine.
    Any idea's?
    Regular Member LADmachining's Avatar
    Hampshire
    AM reception has been questionable on most cars since the year dot.
    When I have had to rectify AM reception problems in the past, the following steps have been taken:-
    Clean and tighten serrated securing nut on aerial base.
    Replace aerial cable with a one-piece front to rear cable. (This was on older Vx's, and used older style ISO aerial connector, rather than the newer Fakra type.)
    Replace aerial base.
    If all of the above fail, then the problem lies with the head unit, which should be exchanged or repaired.
  1. Radio problems again!!
    By lencuff in forum Electrical & ICE (including SatNav)
    Last Post: 25th August 2011, 19:55
  2. Radio Problems
    By Madaxeman in forum Vectra C / Signum Troubleshooting
    Last Post: 18th February 2011, 01:43
  3. Radio AM band problems
    By AlanT1 in forum Electrical & ICE (including SatNav)
    Last Post: 12th September 2010, 13:44
  4. Radio Problems
    By lutontownfan in forum Vectra C / Signum Car Chat
    Last Post: 7th December 2009, 19:43
  5. Radio problems
    By johnsav in forum Electrical & ICE (including SatNav)
    Last Post: 4th August 2009, 18:11
