Thread: Throttle Position Sensor...
    Full Member GazVXLINE170's Avatar
    Jun 2007
    Scotland
    Vehicle : Insignia
    Trim : SRI VX-Line Nav
    Engine : 2.0 CDTI [170 PS]
    Year : 2015
    Mileage : 27000
    Default Throttle Position Sensor...
    With regards to the following thread:
    http://www.vectra-c.com/forum/showthread.php?t=112658
    The car finally decided to through a fit today, spanner light and ABS/TC light came on. The engine would sit at 1,500rpm and this was independant of throttle position ie the throttle pedal done nothing.
    Got it to a local garage who plugged it up for nothing and it has thrown up a fault relating to the sensor at the top of the pedal, however as the diagnostic was general I was urged to go to either Vauxhall or a local Diesel specialist for full proper diagnosis - ie to check if it is a faulty throttle sensor, dodgy connector/connection, ECU etc.
    If it was the throttle sensor at the pedal what is the cost i'm looking at?
    Cheers in advance,
    Gazza4
    Insignia VX-Line Nav CDTI 170.
    Regular Member BIG-G's Avatar
    Oct 2009
    thurso
    throttle pedal sensor.price is £128.part number is(93181881).ive just been on the phone to vauxhall to order some parts for my self so i asked about the part you were after.the person in the parts department said you need the full pedal assembly as it comes as a full unit.hope this helps you bud
    Jun 2007
    Scotland
    Vehicle : Insignia
    Year : 2015
    Mileage : 27000
    Quote Originally Posted by vectra vxr View Post
    Thanks m8.
    Gazza4
    Jun 2007
    Scotland
    Vehicle : Insignia
    Year : 2015
    Mileage : 27000
    Got the car back from the dealer and the Throttle Pedal needs replaced. Dealer was quoting £353, but I walked away with just paying for the diagnostic.
    Gazza4
    Regular Member 900ss's Avatar
    May 2008
    Bucks
    Buy a used one
    £20 tops ?
    Jun 2007
    Scotland
    Vehicle : Insignia
    Year : 2015
    Mileage : 27000
    Quote Originally Posted by 900ss View Post
    Buy a used one
    £20 tops ?
    And if it doesn't work, just getting new but I aint using the dealers.
    Gazza4
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    TBH throttle pedal failure is very rare mate
    May 2008
    Bucks
    Depends how much you can get a new one for then?
    Compared with your dealer quote I think the used one seems a good bet lol
    Jun 2007
    Scotland
    Vehicle : Insignia
    Year : 2015
    Mileage : 27000
    I know
    The worrying thing is the car is the dealer has stipulated that they will replace and then 're-assess'. I worry this is a wiring issue or worse ECU problem.
    Regular Member paul wingnut's Avatar
    durham
    Vehicle : vectra sri 150
    Engine : 1900 cdti 150
    very rare for pedal togo more likely be something else .
  1. Throttle Position Sensor Vectra Est. 2.0L DTI
    By bernadette in forum Engine & Drivetrain
    Last Post: 22nd November 2011, 18:38
  2. throttle position sensor
    By Ryan in forum Engine & Drivetrain
    Last Post: 24th November 2010, 21:06
  3. Throttle Position Sensor
    By RichyA in forum Vectra C / Signum Car Chat
    Last Post: 23rd September 2010, 15:12
  4. Throttle Position Sensor
    By Kristypie in forum Engine & Drivetrain
    Last Post: 9th April 2010, 21:14
  5. throttle position sensor
    By Morephun in forum Engine & Drivetrain
    Last Post: 3rd July 2008, 10:30
vectra c dti throttle position sensor
