Thread: Signum dashboard lights and dials not working
    Swindon
    Default Signum dashboard lights and dials not working
    The dashboard lights and dials (temp, fuel, revs, speedo) on my 05 Signum 1.9CDTI all seem to go out intermitently or not come on with the ignition and/or fail to come back on until they have a mind to! The latest development is that the dashboard functions went off this morning, but retained the speed, revs and fuel level indications at the point of going off. I.e. It is now stuck at 55mph and 2000 revs, etc! Can anyone tell me what the problem is?
    Full Member Big Sig's Avatar
    Sounds like a possible CIM failure. However try the "rushy" - clean the abs connector plug.
    Regular Member benny's Avatar
    Feb 2006
    dudley
    disconect the battery for ten min and see if that gets em to work ...
    Full Member
    South West
    From first hand experience of your symptoms, you might want to consider getting it sorted out sooner rather than later.
    My Vec C dials and lights on the dash started playing up and stopping key out and restarting cured it for about a month. It then started to happen more frequent. Eventually it left the car for dead. Not even the central locking worked.. had to manually use the key to open, and put up with the alarm.
    Better to get it fixed whilst the car is still driving than go through the real pain of having to get the car to the garage by towing or back of a breakdown truck.
    Rgds
    Aidi
    Swindon
    Default Reply from SJMIOW61
    I will clean the ABS plug and disconnect the battery - hoping that the problem isn't the CIM module.
    The situation has been deteriorating so concerned to hear the the final chapter could be a dead car on the back of a tow truck. It would be good to know what the resolve was in that case!
    Swindon
    Aidi, what was the final diagnosis on your vehicle? Did you get it fixed and how?
    Full Member
    South West
    CIM Module was knackered. New one in and right as rain. As others have eluded, expect to pay around £400-500 to have it replaced and reprogramed by VX.
    Swindon
    Thumbs up Reply from SJMIOW61
    Thanks for the advice, I will try the quick remedies before such as cleaning the ABS plug before booking the car into vauxhall for the CIM module check and fix.
    I will post an update once resolved.
    Regards... Steve
    Regular Member yysnet's Avatar
    Jul 2010
    Scotland
    Don't pay stealer for such a bill. Most module are fail on power supply. Open and get it fix would be easy. Or, you could buy a second hand one and replaced eeprom of "new" module by "old" module and enjoy.
  1. Dials not working!!
    By kev.whitehead in forum Electrical & ICE (including SatNav)
    Last Post: 5th May 2012, 17:14
  2. Instrument Panel Dials Not Working
    By mick mcm in forum Electrical & ICE (including SatNav)
    Last Post: 18th November 2010, 15:13
  3. Losing dashboard dials when or after rain.
    By CBag7 in forum Electrical & ICE (including SatNav)
    Last Post: 25th October 2009, 19:58
  4. dashboard and interior lights not working
    By raymondlhuk in forum Bodywork & Interior
    Last Post: 26th January 2008, 20:21
  5. dashboard lights not working - help please
    By Ian in forum General Chat
    Last Post: 9th October 2006, 16:25
vectra 05 1.9cdti dials stop working whilst driving
vectra c dials stopped working
vectra c dash board goes off
vauxhall vectra c dashboard problems
insignia speedlimit off
vectra c instrument panel not working
vetra c cdti no dash lights or insturment light
Opel vectra c gts speed stopped working
signum dashboard problem
lights on signum dashboard have gone out
signum not starting no dash
vectra c z19dt no dash
