Thread: BMW E46 Brake Pad Renewal...Tips?
    Regular Member Jezzy's Avatar
    S.E
    Default BMW E46 Brake Pad Renewal...Tips?
    Does anyone here have hands-on experience of changing the front brake pads on a BMW E46? (2004, 54 plate 320D saloon if that matters). I've offered to teach a novice friend how to change his brake pads on his 320, to wean him off garage fees, so if anyone's done the job themselves, any advice on what sort of caliper they have, how the pads are released, any BMW-specific tools required, etc etc? Thanks.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    I did an X3 and they were pretty straight forward, just like any other car
    S.E
    Thanks Mate - you're right... I've just searched for a 3 series forum and found www.E46Fanatics.com and their how2 for the front pads shows this model uses the same brand of caliper as Vecs/Signums (ATE) and the process is identical to ours, even down to needing a 7mm hex key to undo the slide bolts. Should be a doddle.
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    I did think they were similar to the Vec but it was about 2 years ago that I did them, the pad wear sensor is the same design as the vec's too iirc
  1. Tips for painting brake calipers
    By ANDY W in forum Styling
    Last Post: 28th September 2009, 00:16
  2. Brake pad renewal
    By pscocoa in forum Vectra C / Signum Car Chat
    Last Post: 27th June 2009, 15:12
  3. 314mm Brake Fitting - Any Tips?
    By Thomas1 in forum Vectra C / Signum Car Chat
    Last Post: 13th January 2009, 23:08
  4. Brake Disc renewal
    By FRANKA in forum Vectra C / Signum Car Chat
    Last Post: 6th October 2007, 22:33
  5. Brake Pad Renewal
    By VauxVeteran in forum Troubleshooting
    Last Post: 10th April 2006, 00:26
