Results 1 to 2 of 2
Thread: 2.2lt petrol waterpump leak
    Jul 2010
    Queensland
    Default 2.2lt petrol waterpump leak
    Hi,
    My 2.2lt has developed an intermittent coolant leak. I've managed to locate the leak, it appears to be coming from the bottom of the housing or from around the bolt. I'm just trying to work out if a sealing problem between the 2 machined surfaces or is it an indication that the pump is on the way out. The pump doesn't make any noise and I'm not having any cooling problems.
    As I've just been quoted $950 aus for a new pump fitted I want to make sure thats the problem. I just tried to attach a photo with no sucess.
    Any suggestions would be greatly appreciated.
    Regards
    Murray
    Full Member spennny's Avatar
    Blantyre
    You can get a pump for the 2.2 on ebay, if this is your engine
    http://cgi.ebay.co.uk/Vauxhall-Vectr...item255c35b4f3
  1. oil leak from vectra c 2.2 direct petrol
    By bigf in forum Engine & Drivetrain
    Last Post: 30th March 2012, 16:05
  2. bad petrol leak
    By dannydm1 in forum Engine & Drivetrain
    Last Post: 25th April 2011, 18:04
  3. Leak, front end creak, refurb, bent locking wheel key and another leak =(
    By nick-v2.2 in forum Vectra C / Signum Troubleshooting
    Last Post: 15th February 2010, 19:58
  4. waterpump
    By barry0101 in forum Engine & Drivetrain
    Last Post: 21st January 2010, 09:42
  5. Veccy C SRI 1.8 Petrol G/box leak
    By luap2411 in forum Engine & Drivetrain
    Last Post: 6th June 2009, 15:52
