Results 1 to 10 of 13
Thread: Cleaned the throttle body today,.....
    Regular Member omega63's Avatar
    Jul 2010
    Droylsden, Manchester
    Vehicle : Insignia 2.0L CDTI SRI hatchback
    Trim : Black leather
    Engine : A20 DTJ 128 HP
    Mileage : 126,000
    Thumbs up Cleaned the throttle body today,.....
    Thought i,de check and clean the throttle body today, but found the upper and lower inlet manifolds to be almost blocked. It looks like they have never been cleaned before the engine Y30DT as done 85k....
    Full Member spennny's Avatar
    Blantyre
    Got any "After" pics
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    I've done this on my old Y30DT when it had 160k on the clock...you should have seen that The lower manifolds are very difficult to get to and could get tricky without the right spanners so I never removed and cleaned those 2 Haven't noticed any difference after, just VERY dirty fingernails
    Jul 2010
    Mileage : 126,000
    Thumbs up
    Quote Originally Posted by Celes View Post
    It took over 1 hour alone just to scrape the thick black oily, sludge, and carbon build up in the upper manifold. My hands/fingers where covered in it, took the upper manifold to work and cleaned it as best as i could in the engine degreaser bath. Had to leave the lower manifolds as i need the car at weekend, going to Lyme Park on Sunday. Rebuilt it to night and road tested maybe there is alittle difference.....
    EVERYWHERE
    Thanks for that!
    Might have a go at removing the butterfly plate on mine!
    Partly blanking the EGR valve or removing the butterfly plate from the throttle body (if it controls airflow for EGR on the V6?) will help cut down on soot build up quite considerably.
    May 2008
    Derbyshire (south)
    OMG!! That is dirty! I am wondering what mine looks like not, its done 93k & i bet its never been off..
    Jul 2010
    Mileage : 126,000
    Thumbs up
    Quote Originally Posted by diesel dog View Post
    Thanks for that!
    I think the only way to stop this building up is to blank the egr valve off completely, but not sure what effects this would have on the engine management systems.......
    Jul 2010
    Mileage : 126,000
    Thumbs up
    Quote Originally Posted by mitch1965 View Post
    Hi Mitch pretty sure this is why it blew the smoke/soot out over "etd" CAVVY, what you see in the pictures mostly effects diesel engines, can effect petrol engines but NO!!! where as bad as diesels....
    May 2008
    Derbyshire (south)
    No real findings on blanking the egr atm, ut if you do the eml will be on all the time unless you leave it tied up & connected as for the grime, I may investigate mine,,,, mot tomorrow(thurs), see what happens there first..
    EVERYWHERE
    Completely blanking the EGR valve will usually throw up an 'EGR FLOW' code on the V6. Putting a few small 3 or 4mm holes in the blanking plate will provide sufficient pressure change when the EGR valve opens to fool the MAP/boost sensor. You will still be cutting back by at least 75% on exhaust gas/soot flow.
  1. Cleaned the Throttle Body
    By spennny in forum Engine & Drivetrain
    Last Post: 14th October 2011, 08:39
  2. just cleaned maf sensor and throttle body!!!!
    By wallace78 in forum Engine & Drivetrain
    Last Post: 6th March 2011, 00:59
  3. Cleaned my throttle body and EGR (again)
    By danman487 in forum Engine & Drivetrain
    Last Post: 31st August 2010, 12:46
  4. throttle body cleaned and airbox mod done
    By shakey in forum Vectra C / Signum Car Chat
    Last Post: 21st May 2009, 19:33
  5. Anyone ever cleaned the throttle body?
    By Ben999 in forum Petrol Engine related
    Last Post: 10th May 2009, 12:45
