Thread: Changing the front window glass, advice please
    Bristol
    Default Changing the front window glass, advice please
    Hi all,
    I have a vectra 05 with tinted windows, the passenger side doors were damaged, so having replaced the doors, I now need to change over the glass, aswell as converting the rear door from electric to winder(I know why! you may ask but the itnerior trim is for winders, the door I got is electric)
    According to the haynes manual, I need to remove the regulator on the front door to remove the glass, is this right or is there a better way?
    Thanks in advance
    Mark
    BTW, does anyone in BS10 area have a rivet gun I can borrow for a day, cannot find mine anywere and I am loathed to buy another when I will eventually find mine. Free tea and bacon butty,
    Regular Member brigrif's Avatar
    South Shields
    Make sure you use steel rivets and a heavy duty rivet gun. Wind the window down and you'll see 2x 40 or 45 tx screws on the channel. remove them and tilt the glass forward and slide it forward off the rear guides.( it helps if someone moves the mechanism up at the same time for quickness. Refit the same in reverse but be careful not to catch the tint film on the door edge. I'd do it for you for free if you fancy the drive up north.lol
    Bristol
    Thanks for the offer chap, but I think South Sheilds is a little too far but as I say thanks.
    Mark
    Bristol
    Hiya,
    Can I just confirm, you have to remove the regulator to change over the glass? is that correct.
    Mark
  1. Driver's window glass dropped
    By Dal5band in forum Bodywork & Interior
    Last Post: 20th March 2012, 19:19
  2. Fittin chrome window sills/rear quarter glass and a car smash!!!
    By Jow20 in forum Vectra C / Signum Car Chat
    Last Post: 6th December 2010, 01:17
  3. Anti-Shatter Glass/Window Film-where to buy from?
    By Vaux-Man-G in forum General Chat
    Last Post: 4th November 2010, 00:39
  4. Privacy Glass/Window Tints... Norwich area?
    By VeronicaTheVectra in forum East (RO - WhiskyNo7, ARO - Plasma)
    Last Post: 11th December 2008, 17:51
changing vectra c window mec
