Thread: Errors on engine management
    Jul 2009
    Oldham
    Default Errors on engine management
    Please can you help? My 53 plate has failed it's mot on emissions so I checked my errors on engine management and I get lots of errors
    P1565
    P0170
    P0568
    P0302
    P1525
    P1550
    P0202
    P0110
    P0100
    I am aware of some of the issues as my wiring loom kept popping off causing cylinder misfires I have now corrected this issue . . Could this be the reason my emissions were bad or do the other codes point to something else .
    Thanks for any help you can give
    brum
    clear down the error codes and start again
    Jan 2010
    wirral
    yes, correct, get them wiped off (but make a note of them) then drive for a few days and then test again, some of them could just have been glitches on the ECU.
    Then see which ones re-appear and take it from there
    Jul 2009
    Oldham
    I read them using the ignition and pedal trick is there any way to clear them without paying someone to do it for me
    morecambe
    44 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    dissconect the battery mate make shore you have the radio code to hand
    Jul 2009
    Oldham
    Tried that left it unplugged for 1/2 hour whilst alarm went off a few times
    morecambe
    44 Post(s)
    Vehicle : vectra
    Trim : vxr
    only way is machine then i think mate
  1. engine management
    By crazyvectra2013 in forum Vectra C / Signum Car Chat
    Last Post: 30th January 2013, 21:48
  2. Engine lumpy now Engine Management Light is on
    By Fitzy-2.0T in forum Vectra C / Signum Car Chat
    Last Post: 17th July 2012, 16:51
  3. Engine management light
    By Rapala in forum Vectra C / Signum Car Chat
    Last Post: 13th October 2009, 01:07
  4. Replies: 3
    Last Post: 28th April 2009, 19:49
  5. just had engine management done
    By MAF 3.2 V6 GSi in forum Vectra C / Signum Car Chat
    Last Post: 29th June 2007, 19:25
