Thread: wheres my MAF sensor?
    Jul 2010
    birmingham
    Default wheres my MAF sensor?
    as above, ive not idea where it is and, having cleaned the EGR and boost sensor, its my last idea?!?!
    Bristol
    Vehicle : CDTI 150
    Just after the air box, the tube that leads down to the turbo has a cylinderical device with a single electrical plug on it, jubilee clip either side.
    Thats the MAF, be very careful what you clean it with, something that leaves no residue is best i.e. ISO Propayl Alcohol
    Jul 2010
    birmingham
    not wd40 then?! is it likely to be crudded up? also, if i disconnect it, will i be able to test if this was causing the issue or not?
    Mileage : 000
    Electronic cleaner ( from Maplins) might be better than WD 40.
    Jul 2010
    birmingham
    just took maf sensor off, doesnt look dirty or grimed up or anything?
    Jul 2009
    The Rift, Cardiff
    Others have said before that if you go for a drive with it disconnected and there is no difference then it may well be shot. As the sensors inside are small and delicate its hard to notice any contaminants on them, as said above use electrical contact cleaner or maybe carb cleaner.
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Nice to see your other post & job done 'them darn EGR'S!'.
  1. wheres my H.I.D`s :@
    By Tam80 in forum General Chat
    Last Post: 15th January 2011, 17:21
  2. wheres my cup holders?
    By vauxhall-john in forum Vectra C / Signum Car Chat
    Last Post: 1st December 2010, 23:14
  3. wheres my pics gone
    By PAULMAC77 in forum Signature & Avatar Testing
    Last Post: 22nd June 2008, 22:30
  4. Wheres the boost sensor
    By jimbo 1980 in forum Engine & Drivetrain
    Last Post: 31st October 2007, 17:41
