Thread: signum 3.0ltr v6 diesel
    Sep 2010
    walsall
    Angry signum 3.0ltr v6 diesel
    hi to everyone on the forum as i am a new member
    i have recently bought the signum from a small garage around 2 months back.
    the model is a 55 plate 3.0ltr v6 diesel auto signum cdti.
    i have a couple of faults that i need a little help with please lads/lassies.
    after a few days i noticed when the car gets upto running temp it goes into limp mode with spanner fault on dash, once the car is shifted into manual mode & back the fault clears or when the car is left to cool down it also clears?
    the other one i found yesterday, i noticed the air flow meter is on backwards with the arrow pointing towards the rad. i turned it round & straight away it through the engine man light up on the dash.i turned it back round, drove home from work & when i started it up this morning
    thefault had gone off the dash
    all the service's have been done by vauxhall, although it has missed the last one by around 23,000 miles. ( i am getting it done asap )
    can anyone help with the problems & let me know why vauxhall would put this meter on back to front.
    cheers mark.
    do i need to change the gearbox oil?
    EVERYWHERE
    First of all you need to know what fault code is being stored. Then you can make a more educated attempt to rectify any fault.
    And the airflow meter arrow 'should' point towards the rad!
    Quote Originally Posted by porkaboy View Post
    i noticed the air flow meter is on backwards with the arrow pointing towards the rad. i turned it round & straight away it through the engine man light up on the dash?
    When you turned it round, did you disconnect it?
    If so, then you need to wait at least one hour before restarting the engine
    Sep 2010
    walsall
    Default signum 3.0ltr diesel auto
    cheers lads for the info.
    i will try & get the fault code ASAP.
    the fault light has now gone.
    is it still worth me changing the gearbox oil as i do not know when it was changed last, & also is it an easy diy job or an expensive one otherwise the wife will be forced into punishing me?.
    cheers mark.
    EVERYWHERE
    I wouldn't change the oil unless it was contaminated. Is there the correct amount of oil in it? If the changes are going through correctly most of the time, then any fault would seem to lie elsewhere.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    What warranty did you get from the garage? 3 months?
    Sep 2010
    walsall
    no i only had a month.
    Regular Member Jezzy's Avatar
    S.E
    Quote Originally Posted by diesel dog View Post
    You sure? On mine (a Z20NET, not a 3.0, to be fair), the arrow points in the direction of air travel (which sounds logical) and the engine runs totally fine.
    Jul 2010
    edenbridge
    the air flow meter should point towards the rad as teh pipe then bends round and goes into the engine, i thought this about mine the first time i saw it
  1. 2.0ltr dti mpg
    By richje100 in forum Engine & Drivetrain
    Last Post: 22nd March 2012, 19:12
  2. which eibach for the 3.0ltr cdti?
    By tonyblade in forum Handling & Braking
    Last Post: 1st March 2009, 15:06
  3. 3.0ltr cdti or vxr?
    By tonyblade in forum Vectra C / Signum Car Chat
    Last Post: 12th February 2009, 01:36
  4. 2.0ltr 4x4 300 / 330 / 360bhp Mitsi Evo X
    By Big-Pete in forum General Chat
    Last Post: 17th January 2008, 15:44
  5. 3.0ltr V6 Cdti Signum engine warm up time
    By kev666 in forum Engine & Drivetrain
    Last Post: 2nd April 2007, 20:57
