Thread: Rattling from Rear
    Jan 2008
    GLOUCESTERSHIRE
    Default Rattling from Rear
    Hi
    I have an annoying rattling coming from the rear of my Vectra C Hatcback. Most noticeable when driving over bumpy sections of road.
    Recently had it in the garage for another problem and on a test drive the mechanic said it sounded like my wheel bearings had gone.
    I have only noticed it since i changed my rear pads and was wondering if it could be something to do with this?
    Regular Member Jow20's Avatar
    Sep 2010
    Leeds
    Brake pads will be loose i had same problem, not sure how it occurs but had brakes changed and that was it, noise gone. A way to test if it is loose pad is when its doin the noise brake very gently and the rattle will stop. Thats what u want to happen as its a cheap easy repair and at least ul know what it is!
    Regular Member mickydoos's Avatar
    Aug 2009
    Crawley, West Sussex
    I'm having the same sort of problem and have heard to check the drop links and ARB bushes as both are meant to be cheap and easy fixes
    Aug 2009
    Whoops, soprry for double post :P
    Regular Member PeterVV's Avatar
    Oct 2007
    south wales
    Any movement in the wheel to indicate a bearing?
  1. Rear pads rattling like a MF
    By TerrySRIV6 in forum Vectra C / Signum Car Chat
    Last Post: 25th March 2012, 20:17
  2. Rattling rear pads
    By tomo41 in forum Suspension, Wheels & Brakes
    Last Post: 22nd August 2011, 14:55
  3. rattling at rear
    By evil.c65 in forum Suspension, Wheels & Brakes
    Last Post: 20th May 2010, 09:07
  4. Rattling rear brakes
    By h0llyw00d in forum Suspension, Wheels & Brakes
    Last Post: 3rd June 2009, 15:27
  5. Rattling rear hub
    By Phil in forum Suspension, Wheels & Brakes
    Last Post: 5th May 2009, 16:06
