Thread: Gear stick
    Regular Member Vectra King's Avatar
    Jul 2010
    Bolton
    Question Gear stick
    Hey guys,
    got a 52 plate vectra, the bug bear i have with it is every now and then when i go to put it in 5th gear it fells like somthing a trapped/blocking it. It will go into 5th gear its when you shake the gear stick side to side in nuturel, when u pull it to the right toward 5th gear it seem a bit tight and it makes a clicking sound, After a few shakes it goes away. But it keep coming back every so often
    (If you can make sence of what im trying to say) Has any one else had or got this prob.
    I dont think its the gears itself as it goes in and out of gears fine.
    i think it may be somthing to do with the gear stick/functions it self.
    Any help would be great.
    I have had the gaiter off and cant see any thing obvious..
    Regular Member Keithy's Avatar
    Jan 2008
    Dundee
    maybe the linkage is worn or needing set
    Jul 2010
    Bolton
    what you mean by needing set mate?
    needing a set of linkages?
    Jan 2008
    Dundee
    not sure on the vectra but earlier vauxhalls gave similar problems if worn or not set correctly
    Jul 2010
    Bolton
    ok cheers mate,
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Maybe the cables need lubricating a bit?
  1. Gear stick
    By Puffalo bill in forum Bodywork & Interior
    Last Post: 4th January 2012, 18:34
  2. Reverse gear - weak spring on gear stick
    By Dal5band in forum Bodywork & Interior
    Last Post: 20th December 2011, 13:18
  3. gear stick
    By reeseandellie in forum Suspension, Wheels & Brakes
    Last Post: 11th April 2011, 16:32
  4. Vec C 52 plate 2.2 Dti Gear Stick Jumps out of 1st gear on take off
    By ukwanderer01 in forum Engine & Drivetrain
    Last Post: 5th July 2009, 21:43
