Thread: V6 Coolant loss, Help!
    Regular Member v6boy's Avatar
    PRESTON
    Trim : GSI
    Default V6 Coolant loss, Help!
    I recently experienced massive coolant loss when driving down a dual carriage way, i was giving it a bit of welly when all of a sudden, coolant symbol came on so i pulled over ASAP and lifted the bonnet to be greeted with lots of steam.
    When i squeezed the large main radiator hose between battery and engine block i could hear a hissing noise. Anyway it appears i have traced the leak to a bolt, please see pictures.
    The first picture is looking down between battery and engine, the second is looking at the right hand side of the engine in between the wiring looms. There is a bolt right next to what looks like some sort of sensor. It is from this bolt where the cooling escapes. When i tried to nip the bolt tight, it appears to have sheared off
    Has anyone else experienced this. Is this bolt a Banjo bolt? Anyone know what i ask for at the dealers. I guess the Plenum chamber would have to come off to gain access. Please tell me it won't be anything major!
    Regular Member Keithy's Avatar
    Jan 2008
    Dundee
    has the head of the bolt sheared off?
    PRESTON
    Trim : GSI
    Yes, the pic was obviously taken before, now there is nothing there just a great big hole where coolant comes pumping out!
    Jan 2008
    Dundee
    you'll have to drill out the remains. I wouldn't think its a banjo as there is no pipe/hose connected to it
    PRESTON
    Trim : GSI
    I just don't understand why coolant would be gushing from the hole, what if thats a sensor just to the right of the picture and it was a banjo bolt to let the coolant pass over that??
    Jan 2008
    Dundee
    it looks like the washer was used to seal it. Is that actually part of the cylinder head. I'm struggling to tell where it actually is
    PRESTON
    Trim : GSI
    I think so, the main block is just in the background, but the piece of metal this bolt is in does look like the same casting. I haven't got the head of the bolt and once i drill out the remains i wont be able to tell waht went in there.
    Jan 2008
    Dundee
    take the sensor out. i'm sure that is a temp sensor, you'll soon know when you take it out.
    If it is, you should be able to find the correct bolt on the dealers comp
    PRESTON
    Trim : GSI
    Does anyone have an epc to try and identify the bolt i need please?
    PRESTON
    Trim : GSI
    I Have taken some more pics to see if anyone can help identify the bolt i need. Def does seem liek a Banjo Bolt as i luckily found the sheared head of the bolt (in last picture) I really do hope that replacing the bolt will cure the leak.
    It would appear that the sensor in the 3rd pic is some sort of temp sensor.
    Does anyone have any idea what the dealers would charge for this, to gain access it would appear the plenum chamber would need to come off so surely labour shouldn't be far from a spark plug change?
  1. Coolant loss.
    By BigWilko in forum Y & Z30DT Specific
    Last Post: 10th January 2013, 21:18
  2. Gsi coolant loss
    By vectrasri-j in forum Vectra C / Signum Car Chat
    Last Post: 20th February 2010, 15:13
  3. Coolant loss
    By monkeyhinger in forum Vectra C / Signum Car Chat
    Last Post: 26th July 2009, 23:42
  4. Coolant Loss
    By george in forum Engine & Drivetrain
    Last Post: 12th April 2007, 06:39
  5. 1.8 coolant + oil loss
    By Aleco in forum Engine & Drivetrain
    Last Post: 15th March 2007, 21:52
vectra v6 coolant loss
