Results 1 to 2 of 2
Thread: Oh Dear, How bad is a P1125 Fault Code
    Regular Member markm's Avatar
    Oct 2006
    Portsmouth
    Default Oh Dear, How bad is a P1125 Fault Code
    Hi Guys,
    I have the following code popped up on a loan car that the garrage lent me while my Astra comes in,,
    do you think its safe for the engine to drive ?
    Total number of fault codes: 1
    P1125 - Critical system malfunction 2 (refer to checking procedure: trouble code description)
    (05) - Present
    is it safe to drive it back to the garage ??
    Cheers Mark
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    P1125 Throttle position sensor intermittent
    Sounds like either a dodgy connection, or a faulty potentiometer.
    I wouldn't say it's anything you have done (unless you know better), so wouldn't worry about it. I may give them a ring and say the light has come on (has it?), I certainly wouldn't say that I have investigated the fault by using OPCOM etc. You would just be opening yourself up to accusations etc.
  1. Fault Code P1125 for both 1.9 CDTI's - Throttle Position Sensor
    By GazVXLINE170 in forum Engine & Drivetrain
    Last Post: 25th August 2013, 17:54
  2. Fault code P1125 + Emissions light
    By Aaron1976 in forum Engine & Drivetrain
    Last Post: 7th January 2013, 16:52
  3. Fault code p1125 app system help please !!
    By WDUK2005 in forum Engine & Drivetrain
    Last Post: 8th August 2011, 16:36
  4. cdti 150 cutting out fault code p1125
    By wilkesy1 in forum Engine & Drivetrain
    Last Post: 30th October 2010, 17:45
  5. fault code P1125 ??
    By cov in forum Electrical & ICE (including SatNav)
    Last Post: 24th September 2010, 12:10
saab p1125
vauxhall p1125 fault code
https:www.vectra-c.comforumshowthread.php117866-Oh-Dear-How-bad-is-a-P1125-Fault-Code
p1125 code
vectra z19dt p1125 www.vectra-c.com
p1125 fault code vauxhall vectra
vauxhall astra fault codes p1125
vauxhall astra fault code p1125
vauxhall vectra p1125 fault code
vauxhall fault code p1125
p1125 fault code
