Results 1 to 10 of 17
Thread: Front Seat Removal
    Regular Member Tam80's Avatar
    Aug 2010
    Dundee-Motherwell
    Default Front Seat Removal
    aryt guys
    need to remove my front seats as i wanna give the carpet a right good scrub,as its got a fur coat on it under the seats lol
    i had a quick gander and seen wires running along the subframes i think are called
    anything i need to watch for when removing seats ?
    will my seats be heated ?
    (52) plate vectra c 1.8 ls
    cheers
    Aug 2010
    Dundee-Motherwell
    nudge !!!
    Regular Member gibbon7000's Avatar
    lincs
    iirc you need to disconnect the battery before disconnecting the plug under the seat, then undo the 2 torx screws at the back of the rails and push seat forward, should just come out then.
    Wondering lonely as a cloud
    26 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    Have a look at this it will help:
    http://www.vectra-c.com/forum/showthread.php?t=15095
    Aug 2010
    Dundee-Motherwell
    cool nice guide there guys
    but if i disconnect my battery before taking seats out,will i need to find code for my radio 1st ?
    Regular Member Keithy's Avatar
    Jan 2008
    Dundee
    Quote Originally Posted by Tam80 View Post
    Yes. but make sure you leave the car disconnected for an hour before you start work to let airbags discharge.
    No your car will not have heated seats
    Aug 2010
    Dundee-Motherwell
    cool cheers keithy,any ideas where i would find the code for radio ?
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    its on the Carpass
    Aug 2010
    Dundee-Motherwell
    found this on vxon
    How many buttons on the steering wheel?
    6 buttons, and it will need a security code as the car is halfcanbus.
    4 buttons and 2 scroll wheels, then it won't need a code as the car is full canbus networked. Basically the stereo is coded to the car and will only work in that car unless it is divorced by Tech2 before working in another car. And even then it needs tech2'ing into the replacement car before it will work again.
    this mean i wont need a code ?
    Aug 2010
    Dundee-Motherwell
    [QUOTE=kenp;1324695]its on the Carpass[/QUOTE
    seen that mentioned before,whats that ?
  1. seat removal
    By dilan in forum Bodywork & Interior
    Last Post: 29th April 2012, 15:37
  2. seat removal
    By texaspete1973 in forum Vectra C / Signum Car Chat
    Last Post: 5th June 2010, 20:51
  3. Front Seat Removal.
    By FIL 4822 in forum Vectra C / Signum Car Chat
    Last Post: 19th April 2008, 12:18
  4. Front seat belt removal
    By kel123 in forum Bodywork & Interior
    Last Post: 11th July 2007, 17:10
  5. Front seat airbag removal
    By monkeybusiness in forum Vectra C / Signum Car Chat
    Last Post: 27th September 2006, 09:27
