Results 1 to 10 of 23
Thread: CD70 Aux In fitted
    Regular Member djr69uk's Avatar
    Midlands
    Default CD70 Aux In fitted
    Bar tech2/opcom session to activate the aux menu, I hopefully have all the ingredients for aux in.
    Just wanted to share my idea for the location of the 3.5mm jack plug.
    Had a good look round... iphone doesn't fit in the cup holder so didn't want it there. So that left 2 places... modify one of the switch blanks as other members have done or chuck it in the cubby hole. I opted for the cubby hole as the iphone sits there nicely anyway. So the next question is where to situate the jack socket. Could have gone for the factory cubby hole upgrade with built in 3.5mm jack space and then bought the cable to fit, but in the end I decided to drill through from the rear using a nicely prepared factory round indentation as a guide lol! This meant the hole was dead centre at the rear. I used a 5.5mm drill bit and then the Maplin sourced jack socket literally screwed into the hole directly and sat nice and flush. Thanks to a good choice of drill bit the socket sits very tightly in the hole without the need for the front ring to clamp it down.
    So then I just found a short (10cm) stereo jack to jack extender and that connects from the socket to the iphone/mp3 player etc...
    Anyway, you'll see what I mean from these pics. I think it looks OK and is quite practical!
    http://ben.dialnet.com/pics/cd70/261.jpg
    http://ben.dialnet.com/pics/cd70/263.jpg
    http://ben.dialnet.com/pics/cd70/264.jpg
    http://ben.dialnet.com/pics/cd70/265.jpg
    http://ben.dialnet.com/pics/cd70/266.jpg
    http://ben.dialnet.com/pics/cd70/267.jpg
    Wales
    Very tidy!
    Personally I would have put it to the 'side', just to make sure that the rest of the cubby hole can still be used (Not that anithing fits in there anyway lol!)
    Engine : 1.9 CDTi
    Nice and stealthy
    Is it possible to extend the leads and put them in the arm rest?
    Regular Member yysnet's Avatar
    Jul 2010
    Scotland
    Quote Originally Posted by lee gsi View Post
    Nice and stealthy
    Yes. Some modern models already have the lead extented to near the handbrake.
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    Quote Originally Posted by djr69uk View Post
    Nice
    Wales
    Whoah! Resize those pics dude!
    Midlands
    the pics are big that's why i didn't upload them or put them straight on here! lol
    i'll resize them in a bit...
    i was thinking about putting the connector to one side, but the iphone slides in under it anyway so it's fine in the middle
    i must admit i quite like the arm rest option. might see about moving it there!
    Midlands
    Quote Originally Posted by snapsnap View Post
    done
    Midlands
    Update... got the aux menu tech2'd tonight and then came home and soldered the connections to the jack socket properly. Note to self: scotchlocks are b*ll*cks - don't use them ever again!
    Anyway, this is working a treat now and I'm chuffed to bits! Recommend this mod to anyone with a CD70!
    Thanks very much to yysnet for a spot on job on adding the internal components needed for this on pre 2007 CD70s. Top chap and very helpful!
    Aug 2010
    Birmingham
    How easy was it to solder the parts as I saw on the thread that the parts are ****** small. Can I ask how expensive it cost to do the reprogramming? And who did you use since I'm based in midlands as well?
  1. CD70 with MP3 CDs
    By mdb72 in forum Electrical & ICE (including SatNav)
    Last Post: 12th May 2012, 09:04
  2. CD70 Bluetooth fitted
    By gregc in forum Electrical & ICE (including SatNav)
    Last Post: 15th November 2009, 14:04
  3. parrot fitted to CD70 navi
    By lloyd_456 in forum Electrical & ICE (including SatNav)
    Last Post: 17th October 2009, 23:19
  4. AUX socket factory fitted on a CD70 - how do I select it?
    By Big Gaz in forum Electrical & ICE (including SatNav)
    Last Post: 23rd May 2008, 08:55
  5. Fitted for 314mm discs but fitted with 304mm discs
    By Swatty in forum Vectra C / Signum Car Chat
    Last Post: 10th April 2008, 13:19
