Thread: Help with wheel bearing
    Jul 2009
    durham
    Default Help with wheel bearing
    Got a 57 plate 1.9 vectra (150) vauxhall said my rear tyres have cassolated to be honest I think the wheel bearing are in the way out, are they any simple ways to check what it is? Also what prices would I expect to pay from vauxhall for my rear wheel bearings to be done???
    scotland
    do you know anyone wi a vec ?
    change rear wheals and test drive to see,
    I replaced both rear bearing hubs on mine only to find out it was tyres .
    so now got 2 bearing/hubs lying in shed gathering dust
    Regular Member mozzer99's Avatar
    bristol
    Quote Originally Posted by gsxrster View Post
    Exactly the same with me (on a Vectra 'B'). The rear tyres had castellated and were making a significant noise above 50mph, sounded just like a bearing. Changed the bearings to no good effect (old ones in my shed as well....). Then noticed the castellations or irregular feathering of the tyres. Replaced the tyres* and silence.
    Not sure what caused the tyres to castellate though - the new ones seem fine?
    * The tyres were nasty 'Linglong' so I put it down to that make
    Jan 2010
    Sheffield
    I have same car 1.9 150 and had same issue, replaced tyres now all good
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    The easy way to check for bearing wear is to jack up the wheel, clear of the ground and spin it as fast as you can. If the bearing is wearing you will hear the drone change pitch as the speed of rotation changes.
    Bristol
    Vehicle : CDTI 150
    Also wear in the rear upper control arms can cause wear on the inner part of the rear tyres.
  1. UJ or wheel bearing?
    By Endricks in forum Engine & Drivetrain
    Last Post: 8th April 2012, 10:49
  2. Wheel Bearing ?
    By jer75 in forum Suspension, Wheels & Brakes
    Last Post: 30th August 2011, 02:01
  3. wheel bearing
    By stuart bigboy in forum Suspension, Wheels & Brakes
    Last Post: 28th October 2007, 17:07
  4. Wheel Bearing with VX?
    Last Post: 6th March 2007, 00:19
