Thread: Whats this on my F17 gear box?
    Jul 2009
    The Rift, Cardiff
    Default Whats this on my F17 gear box?
    I'm doing a gearbox oil change, as soon as a get a deep socket to remove reverse light switch. While having a look I noticed a metal part bolted to the cover plate thats not on the pics in the HM. Anyone know what it is? Its a 52 1.8 sxi, f17.
    Also anyone know what size socket I need for the reverse light switch?
    Engine : 1.9 CDTi
    Reverse socket is 19mm I think
    Jul 2009
    The Rift, Cardiff
    Quote Originally Posted by lee gsi View Post
    Cheers mate, the ds's i've got have a lip and rubber bit for spark plugs so the connector on the switch don't fit.
    Jul 2009
    The Rift, Cardiff
    Just noticed this is in the photoshop section, not sure how that happened.
    Can any mod's of admin fix it please?
    Jul 2010
    LIVERPOOL
    Vehicle : vectra c
    Trim : sri 100 edition
    Engine : 20t
    Year : 53
    why you taking the reverse light switch off for to drain the oil out of you box, when take the plate off the bottom to drain and to put the oil back in ,the breather hole at the top.
    Jul 2009
    The Rift, Cardiff
    Quote Originally Posted by sharky123 View Post
    It's a pita that the f17 doesn't have a drain plug or filler hole. I did consider using the gb oil level plug to re-fill but it looks a bit tricky to get a pipe round there as it's sort of at the back behind the wheel. Atleast with the reverse light switch its on the top-ish so I can get to it without removing the batt box.
    Jul 2009
    The Rift, Cardiff
    Bump
    Regular Member benny's Avatar
    Feb 2006
    dudley
    the metal part is to keep the gearbox in check when in a crash stops it rideing up in the engine bay keeps it kinda close to the subframe.....i wouldnt fill the gearbox via the reverse light switch ...dran from the lower pan and fill from the breather in the top and check the level from the level plug on the side of the diff ...
    Jul 2009
    The Rift, Cardiff
    Quote Originally Posted by benny View Post
    Ah that makes sense, thanks mate.
    The haynes manual says to use the reverse switch, but I suppose it also says 'unclip' when it means 'cut fingers, swear then smash with hammer'. Where is the breather from the reverse switch?
    Cheers Bill
  1. cdti stiff gear change, removing gear turret?
    By IrishVectra in forum Vectra C / Signum Car Chat
    Last Post: 17th July 2017, 03:14
  2. Reverse gear - weak spring on gear stick
    By Dal5band in forum Bodywork & Interior
    Last Post: 20th December 2011, 13:18
  3. Stiff gear change, gear selection fine though
    By tramman in forum Engine & Drivetrain
    Last Post: 24th November 2009, 23:20
  4. Vec C 52 plate 2.2 Dti Gear Stick Jumps out of 1st gear on take off
    By ukwanderer01 in forum Engine & Drivetrain
    Last Post: 5th July 2009, 21:43
  5. Whats you best top gear challenge ?
    By garyb in forum General Chat
    Last Post: 3rd November 2008, 18:10
f17 gearbox oil capacity
f17 gearbox breather
can i fill my f17 gearbox through the breather on top
F17 gearbox reverse light switch
F17 gearbox reverse light switch change
f17 gearbox oil grade
f17 gearbox fill hole
