Thread: 3.0 V6 auto, am I in limp mode?
    Nov 2009
    Hatton, Derbyshire
    Default 3.0 V6 auto, am I in limp mode?
    Just driven my 04 signum 3.0 auto home and suddenly it "coughed" and the spanner light came on. The rest of the way it seemed as if it was in CVT rather than auto and it wouldn't let me change gears through the manual shift. (it indicated I was in fifth)
    As I pulled away from some lights I realised the car was stuck in fifth so I wrestled with the manual shift a bit and it eventually leapt, with a jolt, down to second. All the rest of the way I could get second or fifth, that was it. Cruise control was also a no-no.
    Is this a gearbox issue? Or textbook limp mode. I can't get it to a dealer until Wednesday, possibly Tuesday, but should I risk driving it or should I summon the RAC to get me there?
    Mileage : 55000
    It would be helpfull if you could read the fault codes, might give some indication.
    Try this it might work on your motor.
    http://www.vectra-c.com/forum/showthread.php?t=81742
    Nov 2009
    Hatton, Derbyshire
    Thanks for that, tried it a few times but it didn't work unfortunately so I'm still none the wiser.
    I'm not sure what happens when it goes into limp mode, so mainly just trying to differentiate between that and a gearbox problem.
    Full Member Big Sig's Avatar
    If you only have 2nd and 5th it could be the gearbox in limp mode. You need the codes read to get anywhere.
    Nov 2009
    Hatton, Derbyshire
    Will it be wise to drive it the 15 miles to the dealer? Or will I be better calling out the RAC?
    Sep 2010
    belfast
    the same happened to me and i am sorry mate exactly as u explained and i had to have it rebuilt and at the minute it is very bumpy changing from third down to second when i am slowing down to drive over ramps let me know the outcome
    As long as the spanner isn't flashing it's ok to drive carefully for a few miles.
    Sep 2010
    belfast
    Default auto box
    im not sure is that me to drive carefully ?? the specialist said i have to let the seals loosen up i reeally havent a clue
    Quote Originally Posted by sox View Post
    Sorry my reply was for the OP
  1. Replies: 0
    Last Post: 25th June 2012, 13:36
  2. Replies: 6
    Last Post: 22nd June 2011, 17:51
  3. Limp mode again
    By craig2.2 in forum Engine & Drivetrain
    Last Post: 5th August 2009, 21:05
  4. 04 signum 2.2 auto gone into limp mode
    By mikaj in forum Engine & Drivetrain
    Last Post: 28th July 2009, 16:15
  5. Limp mode or dead mode
    By JSYSH466Y in forum Engine & Drivetrain
    Last Post: 2nd July 2009, 09:46
