Results 1 to 10 of 14
Thread: Vectra facelift conversion qestions
    May 2008
    RAMSGATE
    Default Vectra facelift conversion qestions
    Regarding the headlights, what headlights can i use ie xenon or just the standard lights, and is there any modding with the wiring loom??
    cheers
    May 2008
    RAMSGATE
    Anyone
    VOTING UKIP IN AVELEY
    8 Post(s)
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    should be a straight plug and play with standard lights ...but if your going xenons then It would probibly have to be tech2-ed and I'm not to sure about the wiring loom .
    Regular Member Keithy's Avatar
    Jan 2008
    Dundee
    looms for headlights are the same, you can use standard bulbs as facelifts do
    Sunny Dartmoor
    You can use standard headlight with no modding to the wiring loom or you can use xenon's and modify the wiring,hth......
    Pipped to the post.........
    May 2008
    RAMSGATE
    cheers guys, if i use xenons why does it have to be tech 2'd
    Jan 2008
    Dundee
    you can use an aftermarket kit which doesn't need tech2
    May 2008
    RAMSGATE
    what modding is required? is it just the facelift plug that needs wiring onto the loom?
    Jan 2008
    Dundee
    facelift plugs are the same mate. i'm doing this now
    May 2008
    RAMSGATE
    ok then so what modding is required? i know i need the non afl xenons,
  1. Facelift conversion HELP PLEASE
    By mattbrad30 in forum Styling
    Last Post: 15th June 2012, 21:10
  2. Facelift conversion
    By Mrtn_g in forum Vectra C / Signum Car Chat
    Last Post: 24th January 2012, 12:24
  3. Facelift conversion so far
    By blackbeauty in forum Styling
    Last Post: 4th December 2011, 17:19
  4. FAO everyone who has done facelift conversion
    By Keithy in forum Vectra C / Signum Car Chat
    Last Post: 28th December 2010, 11:42
vectra facelift conversion
