Thread: airbag light
    Edinburgh
    Default airbag light
    Since hoovering out my car, my airbag light has came on. I think I disturbed one of the electrical boxes under either the drivers seat or the passenger seat, are these related to the airbag? (perhaps detecting if someone is sitting in the seat or not?)
    Thanks.
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    Have you looked at the 2 electric boxes 1under each seat youve probably disconected one of them
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    As above..
    Unplug the connectors (I think they are yellow - cant quite remember) and plug them back in..
    Should sort then. Wondering if you will need the code cleared mind - shoudlnt have too.
    Regular Member djr69uk's Avatar
    Midlands
    sounds like you've disturbed a connection to the seat belt pre-tensioners? as above check the connectors under the seats.
    Edinburgh
    yup was the connector, the one under the drivers seat was loose. Reconnected and light out thanks chaps
  1. Airbag light!
    By joee91 in forum Electrical & ICE (including SatNav)
    Last Post: 25th June 2012, 01:52
  2. Airbag light
    By Sharpy28 in forum Electrical & ICE (including SatNav)
    Last Post: 12th June 2012, 22:26
  3. AIRBAG light .. is thier a fuse the the Airbag ecu ?
    Last Post: 10th September 2011, 13:21
  4. Airbag Light
    By rocket999 in forum Electrical & ICE (including SatNav)
    Last Post: 18th August 2011, 16:22
  5. Airbag Light
    By Hollingsworth87 in forum Vectra C / Signum Troubleshooting
    Last Post: 16th April 2011, 16:29
