Thread: Fault In My HIDs?
    Regular Member LAZZEE RARSE's Avatar
    Jul 2010
    Sheffield
    Default Fault In My HIDs?
    Dont know what is wrong with them :s
    Bought them around a week ago, the bulbs were lightly superglued in because i had no clips in my lights
    Then the ballasts were held up to stuff by ties, ( one to some wiring, the other to the metL framemabove the headlight)
    First time i used my HIDs they were fine... For about a minute then they switched off :s
    Went to the guy who fitted them, he said the ballast were over heating, said will need bigger ballasts,
    My friend who ordered them said he gave me the HID kit he uses and hes never had a problem with them, he also said everyone else who ordered them off him never had a problem.
    I had a play about with the HIDs, i couldnt pull out the bulbs as they were superglued, but changed the ballasts round and what not,
    Found that after i taken the ties off, the ballast didnt overheat, yet still cut out at around the same time,
    I took one of the ballasts out ( so just one headlight) and the bulb lasted much longer, tested this with both ballasts one at a time with each bulb, results still showed they lasted longer with one headlight.
    Does anyone know what the problem is?
    At the moment i think my car needs a bigger fuse for the lights?
    caistor
    is your car full canbus and did you get the full canbus kit???
    Regular Member Dazzy2006's Avatar
    Notts
    What hid kit did u use?
    To tell the truth it wouldnt surprise me if the way they were bodged together didn't break something
    Regular Member crespo's Avatar
    Bournemouth
    You need cancelors by the sound of it. And dont glue the ****** bulbs in you plank.
    You can modify the original bulb holder to work with a HID kit.
    With the lights on does it effect your radio signal.???? If it does you have a cheap rubbish kit and my advise would be to remove it and get a decent one.
    Jul 2010
    Sheffield
    Tbh i dont know what kit i used and dont know if my car is full canbus ( dont know what that is)
    I waited 2week for the kit so was in a rush to get them fitted
    I personally didnt Glue them in the mechanic did because he didnt have any clips,
    Dont have no interferance with my radio when there switched on
    I have. 07 Vectra sri
    Notts
    Your car will be full canbus
    Dont the cancellors just remove the dash errors crespo
    I cant see it being a fuse problem, to be honest the kit/ballasts are probably duff so cant you send it back for a refund/replacement (less the superglue)
    Bournemouth
    Quote Originally Posted by Dazzy2006 View Post
    With my HID's direct kit my drivers side headlight would go out after a while if you dont fit the Cancelor they supplied with the kit. It would also say the drivers side fog was blown every now and then as well.
    With the cancelor fitted it solved all issues.
    This is what i got.
    http://cgi.ebay.co.uk/BULB-WARNING-A...item33510404ab
    They just fit between the ballast and bulb. and sort out any shut downs, Flickering or bulb warnings.
    2 Of these should sort out the OP's shut down problem. Next day delivery as well.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Another option is to get the car tech2'd so that it thinks it has factory fit Xenons
    Notts
    Quote Originally Posted by crespo View Post
    This is what i got.
    I have a set of those cancellors sat in my shed
    They came with the ultra kit from hids direct but when i fitted them my lights didnt work at all but without them they work great - no errors/strobing etc
  1. Fitted hids but now light fault
    By nick6515 in forum Electrical & ICE (including SatNav)
    Last Post: 24th November 2012, 22:18
  2. Replies: 15
    Last Post: 9th July 2011, 22:19
  3. mot with hids
    By cutchy in forum Vectra C / Signum Car Chat
    Last Post: 16th March 2011, 22:02
  4. Hids
    By dannyp in forum Electrical & ICE (including SatNav)
    Last Post: 7th March 2011, 14:11
  5. hids
    By daddyjay in forum Electrical & ICE (including SatNav)
    Last Post: 9th October 2010, 21:23
