Results 1 to 10 of 21
Thread: Undecided...
    spoons
    Guest
    Default Undecided...
    My Vectra VXR was registered in May 2007 and its now out of warrantee
    Its done 29000 miles and has been generally faultless... except the handling is now getting a bit sloppy for my liking.
    So the options are:-
    1) Replace the existing VXR IDS+ electronic dampers with new ones
    2) Replace the existing VXR IDS+ electronic dampers with mechanical coilovers
    Option 1 means you keep the standard setup, but just refreshing it
    Option 2 means you loose the IDS+ electronic damping feature but gain racing suspension which is adjustable.
    The coilovers I'm looking at are KW Variant 2
    Any thoughts, suggestions or opinions?
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    I'd swear to God I had seen dampers and other suspension equipment designed to work with the IDS system, is this something you'd looked into?
    spoons
    Guest
    Quote Originally Posted by cont1204 View Post
    There are systems that connect with IDS systems for Porsche, VW, Audi etc..
    Nothing for Vectra VXR..
    Its hard enough to find anything for the Vectra VXR as it is !!
    Nobody makes stuff as there isnt the demand like other brands..
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    Ah fair enough. I knew I'd seen it just couldn't remember exactly which make it was for.
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    the handling is sloppy after 29k! thats put me off buying a vxr
    Regular Member chuckleuk's Avatar
    Jul 2010
    Swadlincote
    I'd be crapping my self in a vxr then, the 1 on top gear had bad enough handling.
    Are you VXR Enough
    13 Post(s)
    thats only cos they switched the traction control off and made it look worse then it really is
    How can you tell, it's not run in yet, you need to get out more Spoons ....................
    spoons
    Guest
    No...
    Thats not what I said....
    What I said was...
    Quote Originally Posted by spoons View Post
    ...except the handling is now getting a bit sloppy for my liking.
    'my liking' is hard or track prepared.
    It was 'acceptable' on DAP racing springs and when fairly new, but now its only good for motorway cruising.
    I want 'hard' again, as thats what I like
    Full Member Big Sig's Avatar
    Quote Originally Posted by chuckleuk View Post
    You believe that your greener than you look
  1. Undecided ???
    By antowens in forum Vectra C / Signum Car Chat
    Last Post: 26th March 2012, 12:36
  2. Undecided
    By Marcosuk in forum Vectra C / Signum Car Chat
    Last Post: 4th June 2011, 19:11
  3. New mod (still undecided !)
    By FIL 4822 in forum Vectra C / Signum Car Chat
    Last Post: 22nd March 2011, 20:32
  4. Chrome mirrors ? Undecided
    By mark_647 in forum Vectra C / Signum Car Chat
    Last Post: 21st April 2010, 23:21
  5. Undecided - Yay or Nay
    By spennny in forum Styling
    Last Post: 1st May 2009, 21:52
