Results 1 to 10 of 22
Thread: Washer sensor...
    Regular Member danBoy's Avatar
    Jun 2006
    Northampton
    Default Washer sensor...
    I've ordered a front washer bottle sensor for the Vectra to get rid of the low washer symbol on my display, is there any chance someone can post up a picture showing me exactly where it needs to go on the bottle, as I'm selling the car I want to make sure the sensor is properly fitted rather than short it out
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    I put mine almost directly level with and to the right of the bottom of the main body of the pump. Hope that helps.
    Jun 2006
    Northampton
    Quote Originally Posted by Ian-Highlander View Post
    I put mine almost directly level with and to the left of the bottom of the main body of the pump. Hope that helps.
    Thanks, is it just a case of drilling a hole in the bottle and then a grommet around the sensor to hold it in the bottle??
    Ely, Cambridgeshire
    61 Post(s)
    Year : 2010
    Found a pic of mine after I'd done it.
    Yes, drill a large hole, there's a washer available from the dealers for pennies.
    Edit: oh and I meant to the right of the pump obviously
    Jun 2006
    Northampton
    Brilliant, thanks for that, once the sensor arrives I shall get that fitted nearly there now with getting mine finished, although I wonder how much fluid is left in the bottle haha.
    Ely, Cambridgeshire
    61 Post(s)
    Year : 2010
    One word of advice, make sure the hole is EXACTLY the right size and that the washer is a very tight fit both in the hole and on the pump or you'll end up with the problems I had where there was a very slight leak (not even enough for fluid to leak out but enough for air to get in) which reduced the pressure and the pump hardly had enough power to create four jets. I tried replacing the pump, checked all the lines etc etc turned out to be a bad seal on the washer.
    Jun 2006
    Northampton
    Do you know what size the hole needs to be?
    Ely, Cambridgeshire
    61 Post(s)
    Year : 2010
    No, sorry, that was the problem, I "guess-timated".
    Jun 2006
    Northampton
    Think I'll have to do a bit of searching and see what I can find out
    Regular Member leonvectrac's Avatar
    south shields
    post up sizes etc once your done i have this to do still thanks
  1. My washer bottle has no sensor!!
    Last Post: 27th October 2013, 20:21
  2. Washer sensor pin location
    By SlowCoach in forum Vectra C / Signum Car Chat
    Last Post: 6th December 2012, 02:08
  3. Washer sensor
    By bigmac in forum Electrical & ICE (including SatNav)
    Last Post: 5th October 2010, 17:41
  4. washer bottle sensor
    By paulvectrac in forum Styling
    Last Post: 17th September 2010, 19:50
  5. washer bottle sensor
    By kpf1grandprix in forum Vectra C / Signum Car Chat
    Last Post: 2nd July 2008, 23:28
