Thread: Lambda sensor
    Regular Member vectra 120's Avatar
    Washington Tyne & Wear
    Default Lambda sensor
    Hi,
    Still have my EML on with the following code P0455-5A. Has anyone got a photo of under the car showing the lambda sensor.
    Steve
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 65500
    P0455 is; Evaporative Emission Control System Leak Detected. I Googled this and most are coming back with the same story, faulty Petrol Cap. Not sure if this is the case with the Vec though. Have you checked the cap is on correctly?
    Need to check this out looks like its on ok but will check
    Steve
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    There will be a canister that collects fuel vapour. At certain times the engine will 'purge' this canister of vapour by drawing them into the engine intake. There is a valve to control these events called a 'purge valve', maybe the hose has come off, or the valve is stuck? Assuming it's not the cap (which I doubt)
    PRESTON
    Quote Originally Posted by Ste View Post
    Do Veccy diesels have a canister for this?, i understood these were only fitted to petrol engine cars. If the vent hole in a petrol engined car is blocked, it can cause vapour canister issues, leading to eventual fuel tank implosion.
  1. where to buy Lambda Sensor
    By signum04 in forum Electrical & ICE (including SatNav)
    Last Post: 4th May 2012, 08:56
  2. Lambda sensor
    By danno91 in forum Vectra C / Signum Troubleshooting
    Last Post: 26th August 2011, 16:06
  3. Lambda sensor
    By dan1983 in forum Vectra C / Signum Car Chat
    Last Post: 19th February 2010, 13:08
  4. lambda sensor
    By deg in forum Vectra C / Signum Car Chat
    Last Post: 2nd November 2009, 18:35
  5. Lambda sensor - Z32SE - where is bank 1, sensor 1?
    By Kev_A in forum Vectra C / Signum Car Chat
    Last Post: 23rd February 2008, 14:46
