Thread: Please help!!!!!
    Jul 2009
    durham
    Default Please help!!!!!
    I drive a 57 plate vectra sri, will a sat nav system fit straight into mine from another vectra w/out any hassle??
    Full Member keefy*2010's Avatar
    Jul 2010
    Grain, Rochester,Kent
    Vehicle : Vectra C Facelift
    Engine : 1.9Cdti 150
    You will need to get the CD70 divorced from the donor car and matched with your car on Tech2
    Full Member Big Sig's Avatar
    Plus a tom tom is still much better.
    Full Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    no tech2 needed to remove or install a CD70, you only need tech2 if you are wanting to separate the screen from the headunit for some reason.. I installed mine with no probs at all, you just need to get a Fakra GPS antennae if you find you have not got one in your loom when you remove you current headunit.. You can spot the GPS antennae easily as they have a light blue connector.
