Results 1 to 3 of 3
Thread: My vectra?
    Jul 2009
    durham
    Default My vectra?
    Hi there i own a 57 plate sri 150, its got 41k on the clock, i have owned it for 18 month now and touch wood apart from replacing the wiper motor (warrnty) the car has been fine (touch wood) what are the comman faults with this car? Also what are the tell tail signs to look out for?
    Regular Member ph67's Avatar
    Northamptonshire
    I Don't want to come across negative, the main signs I've seen are these, there a plenty of threads on this site about these. I have the V6 CDTi but the first two are common the the chassis almost regardless of engine.
    1. Excessive Negative Rear wheel camber - Signs: rear tyres wear excessively on the inner edges / rear wheels visibly lean in at the top and out at the bottom when viewed from behind.
    2. Wheel bearing wear - Signs: Loud rumbling / droning from suspect hub(s)
    3. EGR valve clogs up - Signs: Blue smoke, loss of power, erratic tickover
    Jul 2009
    durham
    Thanks for that, I have the 19'smy tyres have already casolated, I get a slight puff of smoke on a morning but fingers crossed have never had any power loss or anything like that, what price does it normally cost from v/ hall to replace the valve
  1. mods could i do to my vectra 1.9cdti vectra suggestion of cheap vxr bumpers
    By lynchy-- in forum Vectra C / Signum Car Chat
    Last Post: 6th January 2013, 00:17
  2. Vectra b rose bush for vectra c rear upper control arm
    By supernova_abh in forum Suspension, Wheels & Brakes
    Last Post: 14th September 2012, 19:26
  3. Silver Vectra (Vectra C Sticker) Southport Ocean Plaza DU56
    By mishima in forum Spotted or put a flyer on a Vectra C/Signum or Insignia?
    Last Post: 29th September 2011, 23:25
  4. Replies: 9
    Last Post: 17th July 2009, 12:07
