Thread: heater resistor keeps going
    New Member nickp1975's Avatar
    wolverhampton
    Default heater resistor keeps going
    I have got a 53 plate, 2.0dti, vectra with air con and i have got through 3 heater resistors since april this year, has anyone else had this problem and found an answer,
    nick
    Regular Member Keithy's Avatar
    Jan 2008
    Dundee
    i would look towards replacing the motor mate
    May 2007
    West Yorkshire
    could be the motor sticking and causing this.
    Lincs
    I had my motor replaced as after it had gone through 2 resistors, one night the cabin filled with dense smoke and a screeching noise
    A new motor cured all, but it was all caused by wet carpet/blocked drain syndrome
    Regular Member benwalters82's Avatar
    Nov 2009
    Redruth
    Trim : SXI
    Engine : 2.0DTI
    Year : 2002
    went thru 3 resistors in 4 weeks. Luckily i did the maplins thermal fuse fix so didnt cost a fortune.
    My fan motor would give a screech when first switching it on and i had to wack it up to number 4 to get rid of it.
    Did a bit of a search on here and then put lots of 3 in 1 oil on top of the spindle behind the pollen filter which cured the squeek and the resistor problem.
    Apr 2006
    york
    hi - may blower doesn't work untill I select number 4 - so assuming it's the resistor. I have taken of the glove box but cant see the resistor assembly.
    Any ideas where I should be looking ?
  1. Heater resistor
    By leeky1 in forum Electrical & ICE (including SatNav)
    Last Post: 3rd February 2013, 18:22
  2. Heater resistor
    By SlowCoach in forum Electrical & ICE (including SatNav)
    Last Post: 4th November 2012, 10:45
  3. Heater resistor?
    By lencuff in forum Electrical & ICE (including SatNav)
    Last Post: 7th February 2011, 19:31
  4. Heater resistor?
    Last Post: 6th February 2011, 22:22
  5. Heater Resistor
    By djr69uk in forum Parts for sale
    Last Post: 23rd October 2008, 19:37
