Thread: 05 Vectra CDTi - ticking when cold
    Sep 2010
    West Lothian
    Default 05 Vectra CDTi - ticking when cold
    Noticed a top end ticking/tapping when the engine is cold, but disappears after about 1 mile.
    I'm thinking maybe a lazy tappet?
    The car has covered 95K miles....any ideas?
    Thanks again
    Regular Member mozzer99's Avatar
    bristol
    Make sure the tapping is not coming from the cambelt area, Undo the top few bolts on the cover and pull it back to be sure that the pulleys are not going or the belt slack.
    Sep 2010
    West Lothian
    Quote Originally Posted by mozzer99 View Post
    Thanks for that, but defo not the belt.
    Incidentaly, had the belt, idle wheels & water pump replaced 5k ago, but noise there b4 and after.
    Sep 2009
    Glasgow
    what am i looking for, sings of wear on the pulleys or something else
    PRESTON
    It might be tappet related as part of the 100k service is to have the valve clearances checked and re-shimed if they are out of tollerance.
    bristol
    Quote Originally Posted by barney490 View Post
    Oh dear - another job I didn't know needed doing!
    bristol
    Quote Originally Posted by nokiaman1978 View Post
    Unfortunately you can't check the pulleys just by pulling the cover back, but with the engine running you can see if the belt is too loose and flapping about on it's longest run - signifying the tensioner has failed or other problems such as the water pump bearing leaking/failing.
  1. random cold knock/tick sound when cold - 1.9 cdti
    Last Post: 18th January 2013, 18:59
  2. Hissing sound when Cold Vectra C 1.9 CDTI ELITE 150
    By Elahi_786 in forum Engine & Drivetrain
    Last Post: 12th February 2011, 22:59
  3. vectra 1.9 cdti 150- running cold
    By robk6112 in forum Vectra C / Signum Car Chat
    Last Post: 17th December 2010, 19:10
  4. Ticking when cold.
    By bax in forum Engine & Drivetrain
    Last Post: 5th April 2010, 10:02
  5. 07 Vectra CDTI 150 judder on cold start up
    By andwat in forum Engine & Drivetrain
    Last Post: 1st August 2009, 11:25
vectra cdti ticking noise
vectra cdti tapping cold
1.9 cdti tapping
