View Poll Results: Have you had an issue with aftermarket HID's
Voters
33. You may not vote on this poll
  • Yes
    2 6.06%
  • What problem?
    31 93.94%
Results 1 to 10 of 22
Thread: The legality of HID xenon's
    Sodding Typical on Sea
    Default The legality of HID xenon's
    I read much about these before taking the plunge and fitting a set to my car about the "you'll get pulled" and they are illegal etc etc etc
    Roughly how Many folks here have had issues with MOT's or having had a Tug from fuzz
    WGAF#5
    if there not purple and look oem no problems
    never had an issue on the preface lift by the police or the man for VOSA
    cambs
    hi
    I've been stopped and after a good look around the car,
    no problems with them
    and had 2 mot's now and passed
    By the letter of the law, and I can quote it if needed, they ARE illegal if fitted retro-spectively, unless they are self-levelling with headlight washers. They also require headlamps designed for them, which by chance the Vectra's elipsoidal lenses are the same as used by the factory fit xenons. The problems arise when fitted to normal reflector lenses as these do not focus the beam properly and scatter the light.
    Now, regardless of the above, I fitted a kit to my old Vectra, no problems with it's MoT, and because they weren't blinding anyone (and I fitted some washers nozzles to it, even though they never worked...) no-one cared. I did take them out for an insurance repair, jsut in case though...
    I now have factory fitted xenons in my Signum, so have fitted the kit to my fog lights for the hell of it. Still can't see ****** all with them on, but they look cool...
    Regular Member Keithy's Avatar
    Jan 2008
    Dundee
    never had a problem. passed two mots with them fitted.
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    never had any probs and mot spot on
    Regular Member crespo's Avatar
    Bournemouth
    Had them on my last 2 cars and had no problems with the law or getting through MOT's. My old Volvo went through two MOT's without a mention. I thought they would be an issue as its obvious they are there because they have to warm up for a few seconds and look very blue. But no issues and never been flashed either.
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Read up on the Vehicle Lighting Regulations regarding retrofitting HID/Xenons.... spoke to a few roads policing officers.... then got a kit and fitted it
    As has been said... by the letter of the law a retrofitted kit is illegal unless it is fitting the full system from a higher spec of the same vehicle..... washer system, level sensors, etc
    BUT ... by the wording of the Vehicle Lighting Regulations specifically on this subject, they may be considered acceptable if the kit is fitted in suitable projector type headlamps, may be height adjusted from inside the car (either by manual or automatic means) and passes MoT test criteria - light colour, beam pattern, aim, position, switching, etc
    So the way I see it, if you fit a kit and choose lamps giving a white or nearly white light that points in the right direction with the correct pattern.... you're fine
    Regular Member vectraboyy's Avatar
    Never had any probs on this or the last car with them on!
    Regular Member blues n twos's Avatar
    Seer Green, Bucks
    Two MOT's and not a problem. No interest from plod either
    If you have the silly purple ones I think your going to get a tug as our chavie mates tend to go ott on the colour.
    Keep it sensible with 6000k or so and you will be fine
    Jon
  1. HID legality
    By paul_sri150 in forum Vectra C / Signum Car Chat
    Last Post: 3rd November 2010, 19:34
  2. xenon's the story continues
    By Lump in forum Electrical & ICE (including SatNav)
    Last Post: 14th March 2009, 13:58
  3. Has my Elite Got Xenon's??
    By ukmayhem in forum Vectra C / Signum Car Chat
    Last Post: 22nd February 2009, 17:39
  4. Xenon's? Standard?
    By spark in forum Vectra C / Signum Car Chat
    Last Post: 4th March 2008, 09:15
  5. Xenon's weren't self levelling.
    By SirGSi in forum Electrical & ICE (including SatNav)
    Last Post: 20th September 2005, 14:38
