Thread: 05 Vectra CDTi - Fan problem (not resistor!)
    Sep 2010
    West Lothian
    Default 05 Vectra CDTi - Fan problem (not resistor!)
    Hi there, been searching this forum and found loads of fan speed problems all linked to the resistor.
    Ok, same problem, only works on speed 4.
    Resistor tested and it's ok. Just incase, it was replaced, still no success. Tried changing the dash control panel, still no success!!
    Any idea's?
    Full Member Big Sig's Avatar
    The fan motor itself? not a lot else left
    Sep 2010
    West Lothian
    Smile
    Thought about that, but not sure.
    The fact it works on high speed tells me (maybe wrongly) the motor is fine...all the resistor does is reduce the voltage hence the lower speed??
    Will check it out though.
    Thanks again
    Maybe a lower current supplied isn't enough to turn it? Although i would have thought it would take the fuse out. As you have changed the obvious its time to look at everything else.
    Regular Member yysnet's Avatar
    Jul 2010
    Scotland
    Did you check UEC?
    Regular Member djr69uk's Avatar
    Midlands
    Maybe this'll help...
    http://www.vectra-c.com/forum/showthread.php?t=56294
    Money goes on the relay! Good luck
  1. Problem disconnecting resistor block
    By Rob1966 in forum Electrical & ICE (including SatNav)
    Last Post: 18th September 2012, 12:57
  2. Vectra CDTI SRI 150 rev problem
    By dan912 in forum Engine & Drivetrain
    Last Post: 31st May 2011, 10:27
  3. my bro`s 120 cdti sri vectra oil problem
    By chris6409 in forum Vectra C / Signum Car Chat
    Last Post: 26th November 2010, 12:13
  4. Problem with Vectra 1.9 CDTi 150
    By Manni2375 in forum Engine & Drivetrain
    Last Post: 18th March 2007, 17:21
