Thread: Parking sensor with "trailerhook"
    Aug 2010
    Norway
    Default Parking sensor with "trailerhook"
    I want to mount aftermarket parkingsensors on my car . But i have a "trailer hook" (sorry for bad english) . Is it anny signal i can use to controll the parkingsensors so they are off when I use the trailer ?
    Engine : 1.9 CDTi
    You could fit a switch inline of the power or earth feed to the control box.
    Regular Member crespo's Avatar
    Bournemouth
    or you could just unplug the noise box when using a trailer.
    Regular Member luke4487's Avatar
    Bordon, Hampshire
    The rear parking sensors on the standard sensors only work when you have been in reverse gear Hope that helps, maybe hook up the circuit via a switch with reverse gear?
    Also the standard ones with a tow kit installed correctly to the cars electronics disables the rear sensors.
    Aug 2010
    Norway
    Default Now we are talking .
    Is it possible to get this signal or do i need te standard parking sensors ?
    If possible i i onle put inn a relay !
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 65500
    Quote Originally Posted by lee gsi View Post
    That's what I would do too. Just get a small switch and fit it in through the boot lining and either split the live or the negative and you can switch them on of off from tinside the boot. Or you or you could run a wire all the way to the dashboard and put a switch on one of the spare points the dash and run a wire all the way back.
    Quote Originally Posted by staverh View Post
    Sorry i have no idea
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    You should be abel to use a relay..
    as then power going through a specifik wire, then cut power on the other circut.. i dont know what type of relay you should use but should be possible.. but probaly more easy just to put in a switch.
  1. "Winter" Wheels ? Are 19" Snowies best for the "Summer" ?
    By Woody in forum Vectra C / Signum Car Chat
    Last Post: 5th October 2012, 18:43
  2. Lambda sensor "size"
    By urbanfox in forum Vectra C / Signum Car Chat
    Last Post: 16th July 2010, 20:29
  3. Any legal types help with "private" parking rip off fine.
    By Old man Jimbo in forum The 'Off Topic' room
    Last Post: 16th April 2010, 18:12
  4. Parking row "led to mans death"
    By Paulsvectra in forum The 'Off Topic' room
    Last Post: 24th February 2008, 19:53
