Thread: Strut tops?? Part number?
    Oct 2007
    Shropshire
    Default Strut tops?? Part number?
    Sorry if this has been asked before. My front suspension squeaks over bumps and after droplinks and arb bushes, I believe it may be the strut tops.
    Which bit do I need to replace? The top assembly, the bearing, or it all? I know it is reasonably common for it to go and I have found lots of threads about changing it but which bit do I need??
    Does anyone have the part number and idea in approx cost per side?
    Thanks Again...
    preston
    try vauxhallworld parts
    you'll need a new bearing at least per side. its probably that which is making the noise
    and top mount support..
    for the price i'd change both
    Oct 2007
    Shropshire
    Thanks, what sort of money are they?
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 65500
    www.eurocarparts.com £40 a pair from there.
    Oct 2007
    Shropshire
    Thanks man..
    preston
    top mounts about £25 a side
    bearings about £12
    scotland
    do the mounts wear ????
    or is it just the bearing ?
    not trying to hijack thread lol
    preston
    the bearings get worn out and dry out over time
    someone put a nice photo on a thread recently of a worn bearing but i can't find it quickly
    the main reason to replace both is that if you are replacing shocks / springs you can strip off the old suspension as a unit without taking it to pieces. Then it can go to the bin.
    but cunningly if you have new mounts and bearings ( + shocks n springs ) , you will have been able to prebuild your new unit so making the swap over that much quicker and you can do it at a time to suit you rather than when your car it in bits and that big black storm cloud deposits a monsoon on your head.
    given the loads that are placed on the suspension, and the price of the mounts / bearings, it makes sense to always do it this way to me
  1. What part number is this for?
    By Ziggy in forum Vectra C / Signum Car Chat
    Last Post: 23rd June 2009, 17:00
