The Vectra 'B' DTI engine was carried over to the Vectra 'C' for a couple of years.
This pump has an ECU on top and does the whole lot, pumps pressure and distributes to the injectors.
Difficult to change and ruinously expensive new.
Later CDTI Vectras have a pump that is easily changed and only generates (very) high pressure. It has no ECU on the pump as the injectors are electrically fired. Seems to be a far more reliable system?
The DTI engines can go for 200k miles + without any attention - but ebay sales suggest some can be unlucky with the Bosch pumps. Given that any car fitted with a DTI pump is now over 6 years old it can write the car off.
If you are looking at the CDTI SRI (120 or 150 hp) ask again as there are a few things to be aware of.
