Results 1 to 10 of 13
Thread: disc swap !!
    Regular Member markj23's Avatar
    Aug 2010
    Luton
    Default disc swap !!
    If I was to up grade my front discs and pads would my old front ones upgrade my rears?
    2004 Signum 2.2 direct petrol
    Full Member Big Sig's Avatar
    No
    Aug 2009
    LEEDS
    no lol
    preston
    the rears have the self adjusting handbrake part attached as part of the caliper so nice idea but unfortunatley not possible
    if you want to upgrade rears find a scrap yard braking a late 2003 , 2004 V6 signum or vectra. They carry the 292mm calipers and carriers. I paid £100 for calipers carriers and carrier bolts although you might get it for less if you haggle.
    The rears will then be vented discs rather than solid. Won't massivly improve braking but will make sure that braking is balanced better.
    Are you upgrading the fronts to 314mm or more?
    Aug 2010
    Luton
    thanks Mparks was thinking of 314mm from lmf
    Jul 2006
    Northampton
    Trim : Sri
    Engine : 1.9 cdti 150
    If you do upgrade, i have some spare rear discs and pads that are near new
    Aug 2010
    Luton
    that would be great dan Im in Mk all the time how much you looking for them? so I can get an idea, I have got the calipers and carriers lined up as well, might go for new bolts though how much stress goes through them?
    Regular Member Jezzy's Avatar
    S.E
    Quote Originally Posted by markj23 View Post
    LMF have been out of stock for a year or more.
    Regular Member PORKBALLS29's Avatar
    Epping
    I'd try Neo Bros in Waltham Cross, they're a Saab breakers and will more than likely have some used ones in stock. HTH
    preston
    yes
    they also do a lovely looking 4pot 324mm kit on ebay for £760 ( calipers / carriers/ discs / pads / braided lines )
    but if you want to save money
    go to scrappy, steady stream of V6 entering breakers
    just be cautious as early V6 had 302mm setup so take your tape measure with you or check the VIN - some post on here has the VINs with various disc setup
    calipers/ carriers should cost £100 or no more
    disc / pad set £70 from LMF
    braided lines £50 or so from HEL or others
    so reckon front and rear 314 / 292 replacement should cost not more than £400 .
    then fitting ---- well find a friend who can do it for you
    good luck
  1. should i swap or not?
    By mtqn in forum Engine & Drivetrain
    Last Post: 6th August 2012, 12:04
  2. Would you swap ?
    By wolvesdaz in forum The 'Off Topic' room
    Last Post: 20th February 2012, 18:20
  3. Would you swap...
    By P3tchy in forum Vectra C / Signum Car Chat
    Last Post: 25th April 2009, 11:21
  4. nav disc & 4 disc cartridge
    By rorycarz in forum Parts for sale
    Last Post: 20th June 2008, 22:01
