Thread: Interior light
    Aug 2010
    wilts
    Default Interior light
    signum the front interior light does not work the bulbs are ok the back interior light works fine any help
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    maby the plug have come out.
    Jul 2009
    The Rift, Cardiff
    Try removing the light and sunglasses holder/blanking plate to check the plugs and connection block on top of the light. I'm not sure if the front and rear lights are on the same fuse.
    Aug 2010
    wilts
    cant find any fues for interior lights in book
    Aug 2010
    wilts
    got the light unit out all looks fine
    Full Member Robsey's Avatar
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    The Body control module provides power to the lighting circuits.
    Check fuses 7, 9, 10, 12, 17, 19 and 26 at the passenger end of the dash panel.
    That is virtually everything that affects the BCM. The BCM controls the interior light function.
    Aug 2010
    wilts
    i have looked at the light unit and one of the tracks on circuit board on back of light is damaged so i have ordered a new one from vauxhall 33.00 not to bad
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    I'm sure LMF may have been a little cheaper.
    Or you could have soldered a link wire to join the broken track.
  1. interior light
    By jamiedvvt in forum Bodywork & Interior
    Last Post: 19th November 2012, 17:47
  2. Interior Light - 4th light switch blank ?
    By Woody in forum Electrical & ICE (including SatNav)
    Last Post: 12th November 2012, 23:44
  3. Interior Light Issue - Light & Button Illumination?
    By Leemarksmith in forum Electrical & ICE (including SatNav)
    Last Post: 7th November 2012, 23:36
  4. URGENT:Glovebox Light/Interior Light Fuse
    By Hendry in forum Vectra C / Signum Car Chat
    Last Post: 5th June 2011, 09:13
  5. interior light
    By chrosty in forum Bodywork & Interior
    Last Post: 6th April 2011, 23:06
