Thread: noisey headlight
    norn iron
    Default noisey headlight
    hi guys, im getting a whirrring noise from my drivers side headlight, im nearly sure my headlight level motor has become disconnected, anyone know how i could disconnect the mechanism to stop tis noise?
    Regular Member omega63's Avatar
    Jul 2010
    Droylsden, Manchester
    5 Post(s)
    Vehicle : Insignia 2.0L CDTI SRI hatchback
    Trim : Black leather
    Engine : A20 DTJ 128 HP
    Mileage : 126,000
    Thumbs up
    I also have a "whirring" noise coming from the o/s/f h/lamp, my noise is coming from the electro/hydraulic power steering pump. The pump is mounted to the chassis below the h/lamp and behind the bumper, if i rock the steering wheel left and right the noise changes and sometimes it stops. I need to have the steering angle sensor reprogrammed/calibrated......
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    How about remove the back rubber cover.... try and wiggle the reflector assembly to see if it actually has come lose.
    If it has... remove the main and dipped bulbs... stick your fingers in the holes and pull the reflector assembly firmly back until it clicks onto the ball mounts of the adjusters.
    If that doesn't work you may have to remove the headlamp assembly... remove the adjuster motor... re-seat the reflector assembly... re-fit the motor... re-mount the headlamp.
    norn iron
    thanks for the replys, im nearly sure its along the lines of the headlight assembly, why would it be constantly trying to adjust even though it has probabley become disconnected?
  1. noisey shocks?
    By chris1804 in forum Suspension, Wheels & Brakes
    Last Post: 26th January 2013, 21:02
  2. noisey 1.9 cdti
    By leighhockey in forum Engine & Drivetrain
    Last Post: 14th August 2012, 17:23
  3. Noisey air con fan
    By nikroc in forum Electrical & ICE (including SatNav)
    Last Post: 10th May 2011, 08:10
  4. noisey fan motor
    By tyler boy in forum Electrical & ICE (including SatNav)
    Last Post: 22nd March 2011, 19:13
  5. 2.2 direct very noisey top end
    By mi-tots in forum Engine & Drivetrain
    Last Post: 20th January 2011, 22:52
