Results 1 to 3 of 3
Thread: p0120 help!!
    Sep 2010
    uk
    Default p0120 help!!
    hi everybody!I've got a problem with my vectra c 2.0dti hatchback, y20dth engine,engine starts and working in the safe mode only,no response on the throttle,smoking a bit,scan tool has show P0120 Accelerator Pedal Position Sensor 1 High Input,I've checked the pedal on the second car and is 100% working,I have no idea what is wrong,any sugestions welcome..thanks
    Regular Member yysnet's Avatar
    Jul 2010
    Scotland
    Check wiring. Doggy plugs, dead wires etc.
    Also use the scan tool to see the dataflow from your ecm, there should be pedal sensor position(voltage).
    Sep 2010
    uk
    hi,I've checked data flow fom pedal position sensor 1- 4.88V
    pedal pos sensor 2 - 0.49V
    with foot down PPP1 - 4.92V
    PPP2 - 1.84V
    screws on the ecu pump looks like was remowed before.
p0120 vectra c
