Thread: also spanner light on
    Regular Member costalot's Avatar
    shropshire
    Default also spanner light on
    My spanner light is on when I start up and goes out after 5 mins
    If I turn off for hour or so then back on the light goes out striaght away
    Had a service at vauxhall main in march and they reset the clocks I wander weather it was done right, also if I do nothing will the car go in get me home mode if there is such a thing any ideas thanks
    Farnborough, Hampshire
    If its a diesel then when mine did that it was glowplugs
    shropshire
    I have no probs starting and the plug light goes out quite quick
    I pressed the brake peddle and at the same time pressed trip reset
    and where the miles are shown i had a display of 002 04 what does
    that mean
    The plug light as in the 'coil' symbol? Yeah that was normal on mine too, think thats the plug warming circuit or something like that but a dead plug throws up the car and spanner light exactly as u describe
    Jan 2010
    wirral
    you will get the car and spanner light showing if you have a glow plug fault but it will not go into "limp" mode
    Regular Member DaveW555's Avatar
    Cannock
    It needs the codes read matey, if your over my way anytime i'll plug it in for you and read it. I'll pm you my number
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Quote Originally Posted by costalot View Post
    that mean
    I would check the glow plugs first, but the only codes near to the above i can find are these two.
    P0204
    Cylinder 4 Injector Circuit Open.
    P0024 B Camshaft Position - Timing Over-Advanced or System Performance (Bank 2).
    shropshire
    Thanks guys bit scarey are wizzards codes hope I am wrong with my numbers sounds dear do those............
    By Shadrack in forum Vectra C / Signum Troubleshooting
  2. Problems with Air bag light, ABS, Anti Skid & Spanner light
    By WeDesign in forum Vectra C / Signum Car Chat
    Last Post: 4th December 2012, 21:23
  3. Should I Have A Spanner Light aswell as an Engine Light on My Signum?
    By StreetDragster in forum Engine & Drivetrain
    Last Post: 18th August 2012, 11:57
  4. EGR Valve, Engine Management Light & Spanner Light
    By guygreen in forum Engine & Drivetrain
    Last Post: 12th December 2010, 20:09
  5. spanner light then engine management light
    By learoy69 in forum Engine & Drivetrain
    Last Post: 12th March 2010, 20:10
