Thread: air con not getting cold
    Regular Member wilbur1's Avatar
    wrexham
    Default air con not getting cold
    hi
    i got my vectra 1.9 cdti 56 plate re gased a few weeks ago and it was working fine, i put it on today but its not getting cold its sounds as if its working the engine changes etc but its just not getting cold theres plenty of gas in it but the pipes are not freezing up at all cant understand this as everything seems to be working anybody got any ideas. cheers
    Ashington, Northumberland
    I suspect you have a leak and the refrigerant has slowly dwindled. It has obviously still got some in as the compressor is pulling in, if all the refrigerant had gone, the low side cut-off switch would have disabled the system to protect the compressor. Get a static pressure test done (both high and low side should be sitting at about 5bar pressure). Without looking at it, its tricky to pinpoint the cause, but I would get that checked first.
    wrexham
    Thanks gary i will get that checked
    Halstead, Essex
    @wilbur1 I had the same problem when I bought the car.. I had it re-gassed 2 times in 7 days. After that on a closer inspection and after the colour liquid being added in the system, a small hole in the condenser had been found. After that had been changed, everything seems fine, but I still say that my old vectra 1.8 R reg was getting much cooler and faster as well.
    Yea, all it takes is the tiniest of holes, and the condensor is a favourite for tiny holes
  1. random cold knock/tick sound when cold - 1.9 cdti
    Last Post: 18th January 2013, 18:59
  2. smoke at cold cold start
    By azacbr6 in forum Engine & Drivetrain
    Last Post: 5th December 2012, 18:23
  3. So you think it is cold here.
    By ed taylor in forum General Chat
    Last Post: 23rd December 2009, 15:36
  4. No Cold Air
    By dhwigston in forum Troubleshooting
    Last Post: 18th November 2009, 18:52
  5. A cold one.
    By shan in forum General Chat
    Last Post: 10th September 2007, 00:40
